dead pedal and engine running
Old Feb 12, 2005 | 06:02 PM
kuma's Avatar
kuma
Anyone ever experience a dead pedal. What i mean is enging running but hit the gas pedal truck does not idle up at all nothing. Has happened when starting truck up and put into gear and nothing turn truck off and try again it goes. Also once going down the interstate running good and lost all RPM but truck running would not rev up at all. Pulled off the road turned truck off and also was told to unplug EGR valve (with motor off) and started back up ran fine. That was Tuesday haven"t plugged EGR back in yet. Then today happened again started it up at the Boat shop and put into gear no pedal running but would not rev. Turn truck off back on worked great. Any ideas?????????? Yeah I know take it in but wanted to ask here first see what kind of response first.
Old Feb 12, 2005 | 06:23 PM
me1mckee's Avatar
me1mckee
Sounds alot like a symptom of wire chafing. Do you have adjustable pedals? Also, the throttle potentiometer uses three signals. If one fails, the throttle works normally; if two fail, it goes to idle and will not react to movement. It is possible that your pedal sensor is going bad or that the computer is not reading that signal properly. When you shut off the engine and restart, it basically "reboots" the computer. Yes, take it in, but keep these things in mind and of course, I'm just guessing here so don't harrass them if they tell you it's something different. Good luck. Mat
Old Feb 12, 2005 | 11:11 PM
SBV45's Avatar
SBV45
me1mckee about covered it. I would bet on wire chafe or bad accelerator pedal postion sensor.
Old Feb 13, 2005 | 06:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
This one, as lousy as it is to drive this way, can be fixed easy!~!
They should get this out in one day and back to you.
Old Feb 13, 2005 | 08:34 AM
barkweld's Avatar
barkweld
I have had the same problem and they found the VGT sensor bad ( Variable Gas Turbine ) this will not let the turbine spool. You can sut it off and restart it and it will be fine but the more you do that the worse it gets. It won`t take long to fix. Good Luck
Old Feb 13, 2005 | 10:48 AM
SBV45's Avatar
SBV45
VGT=Variable Geometry Turbocharger. See http://dan.prxy.org/Truck/6L_bible_h.../Page_034.html
In fact, go to http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html and read the whole thing.
Very interesting and full of good info.
Of course I like reading stuff like this.
Old Feb 13, 2005 | 10:50 AM
barkweld's Avatar
barkweld
Sorry about that I am a refinery operator and thats out translation. My bad
Old Feb 13, 2005 | 10:52 AM
SBV45's Avatar
SBV45
hey barkweld, no putdown intended. This site is full of good info and a great place to learn. I don't want to sound like a know-it-all, just want to share good info.
carrzkiss
1983 - 2012 Ranger & B-Series
Jun 2, 2014 07:16 PM
Merculous
6.4L Power Stroke Diesel
17
Nov 1, 2013 10:02 AM
fastbee
May 9, 2011 01:31 PM
Gr8ride
Dec 1, 2006 07:28 AM
norcalbmxer
Apr 13, 2005 01:36 AM
