Overheating?
Old Feb 12, 2005 | 02:00 PM
dscofever's Avatar
dscofever
Question Overheating?
I have my first diesel 2005 f-250. I tow a toy hauler that fully loaded wieghs around 10k-11k. When I go up grades the temp can climb significantly.
  1. Is that normal?
  2. If so, is there anything I can do to help keep the temp down? Right now it's bone stock.
  3. If I do something "aftermarket", would it void my warranty? I did buy an extended warranty for 85k I think.
Any information you can give me would be appreciated. And I am thick skinned, so if I am doing something stupid, just let me know.
Thanks,
Matt
Old Feb 12, 2005 | 03:46 PM
Crash687's Avatar
Crash687
Do yourself a favor, install a good set of temp. guages, EGT and trans. Install the EGT pre-turbo. Those will give you a better idea of how hot your truck is getting.
Have you read thru this:
http://www.fordtrucks.com/forums/sho...d.php?t=303583
Old Feb 12, 2005 | 11:51 PM
J.Lauer's Avatar
J.Lauer
My 2005 had the saqme problem and Ford has a TSB for this condition. They replaced the entire dash cluster for a faulty temp gauge.
Old Feb 12, 2005 | 11:52 PM
J.Lauer's Avatar
J.Lauer
If I remember correctly the TSB # is 05-1-02
Old Feb 13, 2005 | 10:31 AM
dscofever's Avatar
dscofever
I'm sorry, what is a TSB?
Old Feb 13, 2005 | 10:33 AM
SBV45's Avatar
SBV45
TSB=Technical Service Bulletin. Ford puts out service messages like tips and hints to the technical field. Some have posted summaries of the tsb on the web.
Old Feb 13, 2005 | 11:18 AM
J.Lauer's Avatar
J.Lauer
Mke sure you take the TSB # with you to the dealer otherwise they will give the deer in the headlight look. I feel that this site knows more about the trucks then they do. I have to tell the dealer what to do most of the time.
Sarge261
Jan 17, 2012 03:53 PM
mtskibum16
312
Mar 23, 2010 07:29 PM
Boo_Daddy
Aug 28, 2007 06:44 PM
hotrodracer
Car/truck Buying Advice
22
Feb 3, 2005 08:13 PM
Omnicron
1997 - 2003 F150
Aug 14, 2001 08:28 AM
