Jake brake?
Old Feb 12, 2005 | 07:06 PM
Phydeaux88's Avatar
Phydeaux88
I have been to Steves site many times in fact its where I first found out about ensuring TC lock up. I sent him an e-mail asking how to locate the TC lock up circuit I am posting his reply below:
Unfortunately I have only posted the mod on my site I did not do the jake
brake myself.
Post this question to the board
BAZ...
so once again how do I find the TC lock up circuit?
Old Feb 13, 2005 | 11:28 AM
mech2161's Avatar
mech2161
I believe it is the P/Y wire at the trans.
Old Feb 13, 2005 | 12:32 PM
farmb0y's Avatar
farmb0y
Yep, it's the purple wire w/ yellow tracer, coming from the right side of the transmission. Splice into that wire to a switch, then to a ground. You can also have an LED hooked up so you can see whenever your TC is locking up. Here's a link of how I did mine. They say to splice into it by the plug, but I followed the wire to the front side of the cab because I couldnt' get to the plug with the heat shield from the exhaust being right there, it also resulted in less wire being strung out.
http://www.dieselinnovations.com/techfiles/tclockup.pdf
Old Feb 13, 2005 | 01:37 PM
Saguaro_7.3's Avatar
Saguaro_7.3
I was a little confused when I first started reading about the exhaust brake. I understand the priciple, I had an Izuzu 2 ton dump truck (with the 7.8 I believe) straight 6. It had an exhaust brake you could turn on or off. My '97 PSD acts the same way, when I let off the throttle it starts slowing way down, you can really feel it, especailly without a load. Sometimes I barely have to apply the brakes until I'm almost at a stop. I was thinking this is how all PSD's are set up, but begging to think whoever had the truck before put this setup on it. Any thoughts?
Old Feb 13, 2005 | 09:32 PM
Phydeaux88's Avatar
Phydeaux88
OK let me be sury I have this straight all you have to do is ground the P/Y wire in the tranny bundle to lock up the TC.
I figred you would have to supply power to it evidently I was wrong.
I am just asking cause I dont want to torch the PCM
Old Feb 13, 2005 | 11:05 PM
mech2161's Avatar
mech2161
By my diagram you would put power to it. The #1 shift, #2 shift, converter clutch and the coast clutch are all grounded together with the red wire.
Check the P/Y for power when running. If no power tap into it and run the wire inside to a small bulb, ground as needed. The bulb should light when the converter locks.
Old Feb 14, 2005 | 09:00 AM
badabing's Avatar
badabing
OK guys,who is correct here on the T/C lock-up.on the P/Y wire do we need 12v or do we ground,big difference???????Thanks
Old Feb 14, 2005 | 09:49 AM
mech2161's Avatar
mech2161
Check the P/Y with a bulb as stated before. If it has constant power you would ground it, if not you would put power to it with the rectifier diode. I have not done this, my truck is a 6spd.
Old Feb 14, 2005 | 05:19 PM
blackf3504dr's Avatar
blackf3504dr
Wink
One of the simple pleasures in life , shifting for yourself !
Old Feb 14, 2005 | 06:36 PM
farmb0y's Avatar
farmb0y
You take it to a ground! If you use an LED to tell you when your T/C is locking up, that is when you need 12v, to power the LED. Otherwise tap into the P/Y wire to a switch, then to a ground, as simple as that.
Old Feb 14, 2005 | 07:38 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Sorry- didn't read before I posted.
Old Feb 15, 2005 | 11:15 AM
mech2161's Avatar
mech2161
Let me know how it goes.
Old Feb 15, 2005 | 07:06 PM
  #28
badabing's Avatar
badabing
Thumbs up
OK guys I just finished my convertor lock up switch,Tapped in to P/Y wire at grey plug under master cyl.to sw.and from sw. to ground---- works great,thanks for everybodys input.Next I am going to tackle the ehx.brake mod.,not tonight but at a later date,Thanks again folks.
Old Feb 15, 2005 | 07:31 PM
  #29
eeh129's Avatar
eeh129
Exhaust brakes
check out banks power for exhaust brakes and lots of other goodies for your 7.3
ALedbetter1
General Diesel Discussion
Oct 12, 2013 01:09 PM
tennf250
Jul 1, 2007 07:33 AM
cobarjet
Apr 6, 2005 10:46 PM
blue96psd
Dec 16, 2004 11:52 PM
ford4x4offrd
21
Feb 19, 2001 10:35 PM
