Jake Brake
Old Jun 30, 2007 | 06:38 AM
tennf250's Avatar
tennf250
Jake Brake
Any one make a jake brake for 2007 6.0?
Old Jun 30, 2007 | 08:40 AM
Lonewolftx's Avatar
Lonewolftx
Arrow
It is a programming feature of the SCT Xcal2 unit. It has an option to have it on your towing program if you want. There have been a few folks here that has reported on it and how they liked it. Other than that you will find, if you search here, that any other approach is an issue with the motor.
You can start with this one.
https://www.ford-trucks.com/forums/s...earchid=450980
Old Jun 30, 2007 | 11:58 PM
zhilton's Avatar
zhilton
When you ask about a Jake (Jacobs) Brake...are you talking about a true Jake Brake that is on top of the head controlling the valves like on a Class 7/8 truck or a PacBrake like you can bolt into your exhaust that will cause back pressure? A PacBrake looks like a carb butterfly in the exhaust pipe. A Jake Brake is under the valve covers and is a hydraulic device that controls a valve that effects the compression of the motor...I don't understand enough about a Jake Brake to explain how exactly it works.
Old Jul 1, 2007 | 07:33 AM
WishIhada7.3's Avatar
WishIhada7.3
they use the compression of the motor to slow it down....some can be adjusted by how many cylinders you want to brake....also requires a High volume oil pump if the truck is not equipped with one....
WatsonR
May 24, 2014 02:24 PM
ALedbetter1
General Diesel Discussion
Oct 12, 2013 01:09 PM
mhays2
Oct 11, 2009 07:18 PM
kennedyford
Oct 25, 2005 02:03 AM
blue96psd
Dec 16, 2004 11:52 PM
