Dual Tank Overflow Question
Old Feb 10, 2005 | 08:49 PM
DCC's Avatar
DCC
I've posted questions in about ten appropriate threads but still can't get a straight answer. I have the infamous "Fuel Tank Cross-Flow" problem in my '95 F350, 7.5L: My rear tank pumps gas into the front tank because the front tank's check valve leaks.
I cannot seem to get a simple one-word answer to my question from anyone who has made this repair. Here is the question:
Do I need to replace just the pump or do I need to replace the entire Fuel Delivery Module (with the sending unit, pump, etc. in it)?
The pump is a component of the FDM. The FDM is what gets initially pulled out of the tank when this repair is made.
Will someone please have mercy on me and give me a simple answer?
Thanks in advance,
Dan in Colorado
Old Feb 10, 2005 | 09:14 PM
Kansas-Mike's Avatar
Kansas-Mike
Did you see this thread? https://www.ford-trucks.com/forums/s...d.php?t=341697
Old Feb 11, 2005 | 03:38 AM
FordTracMan's Avatar
FordTracMan
My understanding,the fuel pump can't be changed in the FDM.There have been posts concerning adding a check valve instead of a FDM to correct the problem.
Old Feb 11, 2005 | 08:14 AM
DCC's Avatar
DCC
Yeah, a check valve can be added. My Ford guys want $250 for one (NOT!). They are being real dips about this whole thing. And, I did post a complaint at NHTSA already. I have seen posts refering to "replacing the pump" in my year range.
I still need to know if I need just a pump or the whole drop-in unit.
Thanks for your replys.
Dan
digicon
Feb 28, 2015 01:18 PM
linckeil
Dec 22, 2013 03:33 PM
Big350
Nov 11, 2013 11:31 AM
Phillybikerguy
Oct 3, 2009 09:39 AM
DCC
Feb 20, 2005 03:58 PM
