I want to order the Diablo Delta chip, but I cant find the computer box code. I tried following the suggestions from Motorhaven, but im not sure I found the right code. The only thing I could find was a sticker wrapped around some wires, but there is 3 different number, letter combonations on it. They are; F4TB, 12A581 and P260F. The sticker is white with a green stripe on the right side, along with the letters GL in the green stipe.
The second place I looked was under my dash on the drivers side, but there I only found a single wire with the following code: F4TF-15603-AA.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Thanks!!
All of those are part numbers. The code you're looking for is on the computer box, 3 letters followed by one number. You didn't post what the vehicle is so I can't tell you where to find the computer.
