engine swap
Old Feb 8, 2005 | 07:28 PM
ortega's Avatar
ortega
engine swap
Would a 351 w bolt up to my '78 f100's c-6? I don't actually know what engine is in there right now but i know it has a c-6
Old Feb 8, 2005 | 07:46 PM
mark a.'s Avatar
mark a.
Need to know what the current motor is ?
Old Feb 8, 2005 | 07:57 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
While your getting that information......Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE..
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..
See you on the boards.
Old Feb 8, 2005 | 11:57 PM
'961506's Avatar
'961506
Is it a 351 M,C, or W?
Old Feb 9, 2005 | 09:36 AM
Mike G's Avatar
Mike G
First off, welcome aboard!
Secondly, one quick way to tell for yourself, take a look at the top two bolts on the C6 case. If the top of the case bell is flat and the two bolts are 5" center-to-center apart, then it will fit (small block bolt pattern).
--Mike
fenix1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 26, 2013 01:32 PM
fenix1
Bronco II
May 26, 2013 01:30 PM
rocky1074
Apr 15, 2010 08:19 PM
CALINLEIR
Apr 28, 2009 01:47 PM
Country Sweetie
33
Mar 15, 2006 05:53 AM
