While your getting that information......Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE..
We are pleased you have chosen the best source for Fords!
Secondly, one quick way to tell for yourself, take a look at the top two bolts on the C6 case. If the top of the case bell is flat and the two bolts are 5" center-to-center apart, then it will fit (small block bolt pattern).
