Sponsored by: Real Truck
Tailgate adjustment ? 2001 SD 250
Old Feb 8, 2005 | 12:01 PM
browningman42's Avatar
browningman42
I recently bought this 2001 SD 250 , i have noticed that my tailgate is not smooth to open, it seems like the right side releases a little during normal driving, and causes it to bind, making for a tough time opening it. Is there any adjustments on tailgate or has anyone had a similar expierence thanks.
Old Feb 8, 2005 | 12:24 PM
kenneBF250V10's Avatar
kenneBF250V10
I have an '01 as well and occassionally my tailgate is a little hard to open but nothing is binding. All you need to do is remove the 8 screws that hold the access panel on and lube up the handle mechanism. Water occassionally gets in their and has a tendency of stiffening things up. It works for me, give it a try.
Old Feb 8, 2005 | 08:27 PM
high ho silver's Avatar
high ho silver
Make sure that the rubber grommet at the hinge areas are still there. One of mine broke up and fell out causing the tailgate to sit lower on one side than the other and made it hard to open. Also spray the outer latches as well as the handle area.
MS86
Jun 24, 2015 02:57 PM
94xltsc
Nov 26, 2014 07:12 AM
1999er
Jul 24, 2014 05:27 PM
miniowner92
Aug 12, 2013 10:52 PM
2001gocougs
Escape & Escape Hybrid
Dec 21, 2010 11:55 PM
