Aerostar Ford Aerostar
Transmission won't engage when cold
Old Feb 8, 2005 | 08:50 AM
mooksterman's Avatar
mooksterman
Question Transmission won't engage when cold
My 94 aerostar deosn't engage into Drive , reverse or any gear when the engine is cold. Should I repalce the Tranny now? Could a vacuum tube cause this or a bad filter? Fluid fine smells and looks good- level fine - and there is no slipping or hesitation once the engine is warm. I am completely lost.
Old Feb 8, 2005 | 11:37 AM
aerocolorado's Avatar
aerocolorado
There are reports of this occuring on older vans, being especially prevalent when parked on a grade. Also, these transmission are exquistely sensitive to improper fluid levels. Might try adding an additional half-pint of fluid to see if this corrects the problem.
Other sources would recommend adding a can of transmission flush first, driving an hour then performing a fluid/filter change. This assumes the internal valves are sticking and the flush removes deposits and restores functionality. Some swear by it but personally, I have no direct experience with this method.
alduane
1983 - 2012 Ranger & B-Series
20
Aug 4, 2016 07:57 AM
tinman52
May 23, 2015 06:38 PM
twm011
Mar 26, 2015 11:04 AM
Tomlin
Jul 2, 2011 09:24 PM
cmjboyer
Mar 17, 2011 02:53 PM
