Aerostar Ford Aerostar
Beep,Beep code
Old Jan 9, 2005 | 07:57 PM
Hawk1953's Avatar
Hawk1953
Beep,Beep code
new problem for me. 93 3.0 sport Got in it this evening when I started it up it emitted 5 sets of 5 beeps. Of course I have no reference material to any codes that might apply. Will be very grateful for any help. The oil level and tranny fluid are fine. all fluids are at the proper level.
Thanks in advance.
Old Jan 9, 2005 | 10:16 PM
copper_90680's Avatar
copper_90680
Check your oil pressure gage and the connection to the sending unit. It beeps like that when my sending unit died and the pressure reads 0.
Old Jan 10, 2005 | 07:07 AM
Hawk1953's Avatar
Hawk1953
Still Searching
Checked the sending unit and gauge. They are both working properly. Thanks for the info. But no luck. Any other ideas out there?
Old Jan 10, 2005 | 10:51 PM
Racerguy's Avatar
Racerguy
It's probably an air bag warning.
Does your air bag light on the dash prove out when you turn the ignition on?
Old Jan 23, 2005 | 03:13 PM
Tripp16's Avatar
Tripp16
This is an airbag trouble code. I am having the same problem. Check your number 2 fuse, I was told this is one possible cause of this problem. Unfortunatly it was not the cause of my problem.
Old Jan 24, 2005 | 07:47 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome Tripp, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Feb 8, 2005 | 12:41 PM
Tripp16's Avatar
Tripp16
Sorry for the delay in replying, Had to go out of town and had no internet access.
Tim,Thank you for the welcome. I read the guidelines before or or right after registering and understand and agree with them.
Hawk, The 5 sets of 5 beeps is an airbag code that ouccurs when the airbag light AND at least one other problem exists with the airbag system. My problem was the airbag light bulb was blown and the passenger airbag deactivation switch was bad.
Switch price was $89.65
cost to scan to determine problem was $70.00
cost for dealer to install switch was 160.00
I could have replaced switch myself, But would have had to take the truck back to dealer and pay another $70.00 to get codes cleared. So with the time and fuel I would would have wasted on taking off another day from work it was worth the $90.00 to me to let the dealer go ahead and finish the job.
Old Feb 8, 2005 | 05:25 PM
428_cobra_man's Avatar
428_cobra_man
This Couldn't have been an aerostar, as far as I know an aerostar was never made with a passenger side airbag, they only had driver airbags. If you have one with driver and passenger airbags I would really like to see it
bothersome
Feb 7, 2020 02:31 PM
proudfrog
Mar 28, 2016 12:14 PM
pabear89
Escape & Escape Hybrid
Aug 24, 2011 12:57 PM
friday13
Electrical Systems/Wiring
Mar 16, 2007 10:56 AM
John7894
Jan 4, 2005 01:33 PM
