A4OD Swap from C6
Old Feb 8, 2005 | 12:41 AM
deleontow's Avatar
deleontow
A4OD Swap from C6
I am looking to see if anyone has done a change out of the old C6 to the newer A4OD? I am wondering if it is possible and what all would be needed. Also is the speedo electric or cable on these units.
Truck is 1987 F250 Supercab with a brand new Turbo 6.9
Old Feb 8, 2005 | 06:41 PM
PLC7.3's Avatar
PLC7.3
OK do you mean E4OD or AOD............??
Old Feb 8, 2005 | 11:18 PM
deleontow's Avatar
deleontow
As far as I know the AOD was never offered with the diesle, but the A4OD was. I am looking at replacing the C6 with an overdrive. I am wondering what all is involved, I know that the 92/93 with the 7.3 had this trans available.
David DeLeon
Old Feb 9, 2005 | 11:26 AM
mistakenID's Avatar
mistakenID
delontow, there is an AOD and E4OD. You can put the E4OD in your truck but it will be expensive. You will also need a control unit to shift the tranny like this one http://www.baumannengineering.com/tcs.htm.
The C-6 is a tough trans and not real expensive to rebuild, especially when compaired to the E4OD. Personally I'd go with a gear vendor overdrive.
Old Feb 9, 2005 | 02:48 PM
The Kidd's F-350's Avatar
The Kidd's F-350
Are looking for more speed? The e40d is your best option there but they are not as strong as the c6. You can beat the **** out of the c6 more than the e40d, all i am trying to say if you dont need the speed stick with and want a stronger tranny c6 is your option, more speed e4od, the AOD Is a **** ticket tranny I would not buy it.
Old Feb 9, 2005 | 03:03 PM
deleontow's Avatar
deleontow
I really dont tow anything real heavy, I just want the taller overdrive gearing, I already have 3.54 But would like the overdrive. I know that I will need a control unit, but is that all along with the harness or is there more?
David
Blind Driver
Feb 29, 2016 11:43 AM
BuickBrian
Jan 25, 2016 06:59 AM
dinikin
Feb 10, 2007 11:30 AM
78CREW
Jun 13, 2002 08:36 AM
78CREW
May 22, 2002 01:36 PM
