Are E4OD and C6 boltpatterns the same?
Old May 21, 2002 | 01:57 PM
78CREW's Avatar
78CREW
Post Are E4OD and C6 boltpatterns the same?
Have a C6 behind a 351m (and I don't really care what the m stands for)on my 78 F250. I am looking at putting in a 12v Cummins and have found an adapter for the C6 and the E4OD. I would like to put the engine in with the C6 and then put in a rebuilt/ modified E4OD later to spread out my costs. When I am ready, I would like to unbolt the C6 and slide in the E4OD. Does anyone know about the bolt patterns, what about the overall lenght, for driveline resizing?
Old May 22, 2002 | 02:10 AM
msta999's Avatar
msta999
Bolt pattern will be the same. (remember, big block C-6 needs big block E4OD) the length on the E40D is longer so that means modifying the driveshafts. The E4OD is an electronicaly controled transmission. C-6 is not. Lots of work and money you are looking at. C-6 is stronger/will last longer with that engine. Going with a V-12 are you? sounds spendy. Good luck
Old Jun 12, 2002 | 11:14 PM
rikfish's Avatar
rikfish
[updated:LAST EDITED ON 13-Jun-02 AT 00:16 AM (EST)]msta999,
You seem to have good knowledge on trannys..... I just became the proud owner of a donor 85 Bronco w/302 and E4OD(?) tranny/transfer case. I am using the 302 in my Bronco, and neighbor would like to try the tranny on his 77 F150 w/ 460 C6. Do you know if there is an adaptor available, or will this tranny bolt up to the 460. I saw your comment regarding big block E4OD / big block C-6.
Altering driveshafts not a big deal. He'd just like to see how the OD works with his truck, plus it would give him time to rebuild his C-6.
Old Jun 13, 2002 | 12:20 AM
rikfish's Avatar
rikfish
Once again, I goofed..... The tranny I have is NOT an E4OD, but the older AOD....DUH. Same question though...is there an adapter available to mount the AOD to a 460?
Old Jun 13, 2002 | 03:59 AM
V10man's Avatar
V10man
Get ahold of www.jetchip.com (Jet Performance Products) They should have what you need to swap to the E4OD.
Old Jun 13, 2002 | 06:31 AM
DeenHylton's Avatar
DeenHylton
The AOD was never built to go behind the big block, it will not handle the torque. If you want overdrive you need to get the E4OD and then upgrade it to 1996 specs to keep it from failing prematurely. Deen
Old Jun 13, 2002 | 08:36 AM
KJKozak2's Avatar
KJKozak2
Blind Driver
Feb 29, 2016 11:43 AM
Shiny62
Sep 25, 2005 05:18 PM
BigBlockBill460
Jul 24, 2005 02:23 AM
1972 Ford Thunderbird 429 V8
Oct 6, 2002 11:23 AM
78CREW
May 22, 2002 01:36 PM
