Chewing Gum Removal !!
Old Feb 7, 2005 | 04:33 PM
fordman102's Avatar
fordman102
Unhappy Chewing Gum Removal !!
Well the grand kids got chewing gum on the upholstery. Is there a way to get it out. Not sure when they did it. I thought of trying lighter fluid but don't want to do any more damage than has already been done. Any one know a product that will get the gum out with out staining or damaging any worse than it is. Grandpa is not a happy camper.
Old Feb 7, 2005 | 04:36 PM
19gator55's Avatar
19gator55
I have heard that if you ice it down with an ice cube it will get brittle enough that you can remove it from upholstery. I have never tried it myself, it's just something that I've kept in mind in case I ever needed it. Hope it helps!!
Old Feb 7, 2005 | 05:02 PM
ColtM4's Avatar
ColtM4
simple green or some citrus cleaner
Old Feb 7, 2005 | 06:56 PM
Lee E Quicksall's Avatar
Lee E Quicksall
if you can get some of the ''old'' freon and spray the gum it will freeze it and you can flake the gum off. what this will do to the fabric i dont know, but i used this when i did gum removal from carpet when i cleaned businesses and it worked fine.good luck.
later,
lee
Old Feb 7, 2005 | 07:38 PM
stu37d's Avatar
stu37d
Government Teat-sucker
Krud cutter, It's about $2.50 a bottle at Wally World. Also, any orange oil based cleaner. I am currently in the process of retiling a space on my ship and am using the orange oil to remove the excess tile glue- very gummy stuff! The Krud Cutter is great for removing paint overspray, too.
Old Feb 7, 2005 | 08:31 PM
sierraben's Avatar
sierraben
Check out Goof Off.
Old Feb 7, 2005 | 08:45 PM
superspike's Avatar
superspike
Ice it and scrape it off with a blunt edge like a butter knife. I think Goo Gone or Krud Kutter would leave an oil spot
Old Feb 8, 2005 | 01:00 AM
Ghostgunn's Avatar
Ghostgunn
ICe is the best route. Believe me after raising 4 step children and countless nephews and nieces. Just make certain that you freeze the gum really good and not rush it . Or else it will take some of the upholstery with it. Now when your fourteen year old step daughter takes bleach to clean the carpet up -- you can come back and tell about a happy camper...
Old Feb 8, 2005 | 02:54 AM
Ford_Six's Avatar
Ford_Six
I used to use Greased Lightening on gum when I cleaned carpets, it doesn't seem to bleach them at all.
Old Feb 8, 2005 | 04:53 AM
fordman102's Avatar
fordman102
Thanks for all the advise. Think I'm gonna start with the ice and go from there. Gonna get the vacumn and upholstry cleaner out there this week end and give her a good cleaning.
Old Feb 8, 2005 | 07:48 AM
hawk's Avatar
hawk
peanut butter, i aint kidding also great for tar removal.
Old Feb 8, 2005 | 10:08 AM
Frost13's Avatar
Frost13
don't ever eat ice when you are chewing gum, it will turn rock hard!
Old Feb 8, 2005 | 10:44 AM
Kundalini's Avatar
Kundalini
Originally Posted by sierraben
Check out Goof Off.
Goo Gone
it works well!
Old Feb 8, 2005 | 01:19 PM
cigarxtc's Avatar
cigarxtc
Hands down, this is the best method I've used::
Buy a can of compressed air that you clean the computer keyboards with. Only cost a couple bucks. Turn it upside down and spray the gum until it is brittle. Should not take more than 2 or 3 seconds of liquid spray. Then crumble it apart with your hands or put some gloves on. Trust me it works. I've save a lot of carpet patching by using this method to crumble the gum apart after freezing. It will leave not residue or discoloration.
Professional cleaning crews use a product that does the same thing for gum removal.
Old Feb 8, 2005 | 04:50 PM
1984-3/4ton's Avatar
1984-3/4ton
acetylene torch works
