I've been doing some general maintenance on my new bronco (1986 4x4, v8 302, automatic with overdrive) and now Im stuck at the rear differential. I cant get the darn plug loose.
I see the drain plug (the one which is a hollow square that a 3/8" drive socket goes into) but i cant get it to budge. it is completely stuck. I cleaned up the bolt, heated it up, used a big breaker bar, let it soak in penetrant, still not budging. The 3/8" socket is a little loose in the plug, is there a better tool for the job? I dont want to strip it and be royally stuck!
Well here's an update; the plug is now stripped and mangled, so I am screwed. Are there "stripped bolt extractor" type tools made for these type of plugs (plugs that take a male tool)? Are diffs expensive from junkyards?
Looks like im just going to have to drive it until it blows i guess, unless i can get that plug out somehow... any input appreciated!
Another option may be to remove cover and add a fill plug to the cover by drilling, tapping, and using a pipe plug. You should be able to see the normal level by observing where the line is when cover is removed (like looking at your dipstick). I am not sure how thick the metal is on the cover, however this might be a better option than replacing the whole unit with a junkyard one. Perhaps you could just get the cover from the junkyard and experiment with this prior to removing yours. If it works, you can just use the junkyard cover.
Never heard of one, but I'd weld a 1/2" to 3/8" converter into the hole and use a 1/2" breaker to get both out. BTW, I got close to stripping my plug, too, but I ended up glueing in a converter plug before wrecking the fill plug.
Depends on where you live. how much time you have to look for one, how lucky you are, and whether you need LS, or not. I was quoted prices in excess of $600 for an LS rear end, but I've heard people getting one for under $100. I ended up getting one for $450, that included brakes with nearly new shoes.
as for refilling it instead of tapping the cover or replacing the rearend ive seen people put the proper amount of fluid in a big ziplock baggie and place it in the dif and close the cover...as soon as you move the truck the bag will burst and in a few miles the bag will be gone... handy trail fix too... always good to bring ziplocks with on trail runs
If your plug still has integrity and no leaks, go with the rear cover plug addition, makes the most sense. If you have to run a light bead around it to seal it forever with a mig torch. CAUTION: Make sure the ground is as physically near the plug as you can get it. Don't ground where the bearings/gears in the diff could arc causing damage. Using a pipe plug will give you an external square purchase point for removal. I wouldn' t replace the differential for a plug if not other damage is evident.
If you can't get the plug out remove the rear cover to get the old oil out, then refill the rearend by pulling the hose off you axle vent and put you new fluid in through the vent hole. I picked up an aluminum cover from a 2000 Explorer on ebay for $15.00 machined the brackets off for the Explorer now I have a nice cover with a fill plug and a drain plug.
I feel your pain.
My 94' had a stripped out rear dif. plug.
Paid the local shop $150.00 to drill it out, clean the treads ups and provide a new plug.
Hope it dont sick no mo...
