Offroad & 4x4
raymart winch
Old Feb 7, 2005 | 02:43 PM
mstoned1's Avatar
mstoned1
raymart winch
i could not get the search to work so i will try posting. Has anyone ever used or heard of a raymart winch. i can get a 10000lb one for 400 bucks complete with mount and fairlead I really want a warn but i dont wheel alot and cant find one cheap enough
thanks
hagen
Old Feb 7, 2005 | 03:49 PM
monsterbaby's Avatar
monsterbaby
ummm is that like a store brand Kmart
Old Feb 7, 2005 | 03:54 PM
mstoned1's Avatar
mstoned1
its a generic tiawan brand that is sold on ebay and at stores like rural king and harbor freight i just need a little info. I did just find the specs the hp is almost 5
hagen
Old Feb 7, 2005 | 04:23 PM
fishmanndotcom's Avatar
fishmanndotcom
if you do occasional wheeling or just need a winch to tug you out of a soft spot or something they would be fine. i owned a generic brand Ramsey (made by Chicago Electric from Harbor Freight) and they are horrible. i went through 2 of them in less than a year. i did work them hard though. i would sink my trail rig and then winch it all the way out. i did use a ****** block but it is still a lot of stress for one of these winches. the biggest problem is the metal that the casing is made of. it is very cheap pot metal and i broke the case almost instantly the first time i used it. my suggestion is to go out and buy 100' of AmSteel blue or other winch rope. they are a lot lighter and the rope makes winchin much easier.. hell it helped my second Ramsey knock off last twice as long. you'd be surpriused how much weight i reduced by going with a rope and not the metal cable
just my humble opinion though!
-cutts-
Old Feb 7, 2005 | 05:24 PM
proeliator's Avatar
proeliator
Winches are like condoms, you don't want to spend money on the cheapest ones you can find because when they fail you can be in a world of hurt. I've found going cheap usually is more expensive in the long run. Save your pennies and buy a real winch.
Old Feb 7, 2005 | 08:11 PM
mustange70's Avatar
mustange70
Look for a well used warn like the upright (the 8276'ers), then go through the winch and replace any worn parts you can and you should be good to go. This is what my dad did, but he bought a used warn M8000 (good shape, well used though) he had the shop where he got it from (warn dealer and fixer place) an additional 75 bucks, so all he had to do was bolt it on the mounting plate he made (for his trailer, the plate works like a reciever hitch so he can put it inside when not using it). I think the final cost ended up being 500-600 bucks canadian (roughly 400 bucks american), and the winch is like brand new and it will serve our needs perfect for loading cars and such on the trailer, and the every odd farm truck stuck out in the pasture (i made an adapter to use it in a 2" recieve hitch for it). If i were you this is what i would do.
Old Feb 7, 2005 | 08:37 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'm not even going to try to touch this one up; although the possibilities are about limitless (for the sick and twisted)
He's right though. Sure you can buy "all metal" Superwinch hubs. Why? You'll go through 100 sets under the same circumstances as a better (more expensive) brand. You get what you pay for.
Cody
Old Feb 7, 2005 | 08:47 PM
mstoned1's Avatar
mstoned1
thanks everybody i think i might save for the warn or keep looking on ebay. i do have a chance to get a pto for my 205 but i am unsure if i want all the excess weight of a pto winch. also the overhang on the front would probably be horribal anyway thanks. and if any one in the st louis or south central illinois has a winch for sale let me know.
hagen
Old Feb 7, 2005 | 08:51 PM
fishmanndotcom
that's exactly what i did... one of my friends had an 8274 and he thought it was the Warn Classic 8K. i took it off his hands on the spot for $80! i went through it and someone had already replaced all the worn parts so it was like brand new!
i think he has another, i will check for ya
-cutts-
Old Feb 8, 2005 | 01:04 AM
jughead2's Avatar
jughead2
-cutts-
Guess what the wife just got me for christmas?! Anyways were did you get your winch rope and how much was it? Also do you have any ideas on what caused them to break or what I should avoid? (other than getting stuck!) I guess I ought to check into if I can still get that extended warranty!!
Old Feb 8, 2005 | 07:26 AM
fishmanndotcom
sorry for the news jughead...maybe you will have much better luck than I did. what you could do is bolt that one on the trailer and tell your wife you don't want a winch just yet....you are looking for just the right one!
here's a basic price list for those who don't wanna follow the link:
5/16" x 80', 13,700lb winch rope, $110
5/16" x 90', 13,700lb winch rope, $121
5/16" x 100', 13,700lb winch rope, $139
5/16" x 125', 13,700lb winch rope, $172
5/16" x 135', 13,700lb winch rope, $182
5/16" x 150', 13,700lb winch rope, $198
3/8" x 80', 20,400lb winch rope, $150
3/8" x 90', 20,400lb winch rope, $172
3/8" x 100', 20,400lb winch rope, $187
3/8" x 105', 20,400lb winch rope, $198
3/8" x 110', 20,400lb winch rope, $209
3/8" x 125', 20,400lb winch rope, $231
3/8" x 150', 20,400lb winch rope, $275
7/16" x 75', 23,925lb winch rope, $160
7/16" x 85', 23,925lb winch rope, $182
7/16" x 90', 23,925lb winch rope, $193
7/16" x 100', 23,925lb winch rope, $209
7/16" x 125', 23,925lb winch rope, $264
7/16" x 150', 23,925lb winch rope, $314
the great thing is if your winch calls for 100' of 5/16" you can substitute it for something bigger and stronger (like 7/16 x 75') you just can't get quite as much.
i recommend www.RockStomper.com but you can find rope just about anywhere these days.
in fact while i am thinking about it a couple of weeks ago i was in the back clearing out some of our land after a bad storm and was hauling off cut up wood with my 4x4 Kubota tracotr. well i kept getting deeper and deeper in the mud until finally i got stuck... actually i sunk the front end, couldn't see the front tires. i pulled my trail rig down in the woods (i didn'thave 4x4 yet so i was nervous) backed up to a tree. i chained the rear bumper to the tree and ran my winch line (single line no ****** blocks) and pulled the tractor out. winch didn't heitate and rope didn't sweat it. i know it's hard to imagaine on the interent but a 4x4 tractor is pretty heavy to begin with, you add some sloppy sticky mud and it quickly becomes twice as heavy. i love that damn winch rope, I will never go back to cable!
-cutts-
tobyw
2009 - 2014 F150
Nov 6, 2015 06:56 PM
farva66
Aug 26, 2014 03:48 PM
bigred66
Apr 1, 2011 12:52 PM
yzmoore
Offroad & 4x4
16
Oct 28, 2010 04:49 PM
92_FlareSide
Feb 20, 2006 08:51 PM
