transfer case stuck
Old Feb 7, 2005 | 02:00 PM
trash truck's Avatar
trash truck
transfer case stuck
My truck is F150 86' 300 in-line 6, Manual tranny. the connecting shift rod is not on the truck, and it currently runs, minus the fact that it was stuck in 4 wheel low, and I was able to pop it out, but it now is stuck in nuetral at the transfer case.
Any suggestions?
Old Feb 8, 2005 | 04:51 AM
m350's Avatar
m350
Is there any linkage that could be rusted up ? If so spray it with penatrating oil and keep working it. My Bronco linkage was stuck,,would'nt go into low range,,oil did it !
Old Feb 8, 2005 | 07:50 AM
trash truck
just because i am new, and the Haynes Manual does not state otherwise, when I am sitting in the truck, to have the transfer case in regulare 2 wheel, should the lever on the case be forward or back?
Old Feb 8, 2005 | 12:16 PM
dave in toledo's Avatar
dave in toledo
2 wheel
all the way forward is two wheel, one shift back is 4x4 hi, push down and back for n, and sown and back again for 4x4 low
Old Feb 8, 2005 | 10:39 PM
thesprocket26's Avatar
thesprocket26
Check your fluid level. Mine locked up and it let loose once I added some fluid.
jayski
1997 - 2003 F150
15
May 1, 2021 06:45 PM
Mikeyc187
6.7L Power Stroke Diesel
38
Mar 18, 2011 07:16 AM
DBKER31
1997 - 2003 F150
Sep 3, 2009 10:51 AM
vunger1
Southern Region
Nov 7, 2008 09:05 AM
Help I M Stuck
Bronco II
May 28, 2008 12:56 AM
