wind shield wiper module
Old Feb 5, 2005 | 01:59 PM
Trueburton's Avatar
Trueburton
I think the wind sheild wiper module on my truck is bad. But it is my winter beater and i am broke. I was wondering if there was a way to bypass the module. If it eliminates my interval control i don't care i just need them to work. Any one know how to rid this up or have a wiring diagram and i can figure it out myself. Is it even possible to bypass it?
Old Feb 5, 2005 | 05:26 PM
RECTHEGR8's Avatar
RECTHEGR8
I have this same problem, I have a 98 explorer limited and I think the pump went bad because it prob froze up and seized. I have the replacement part and was just wondering if anyone had an idea of how to put the replacement piece in
Old Feb 5, 2005 | 10:37 PM
Franklin2's Avatar
Franklin2
What year truck?
Old Feb 6, 2005 | 10:54 PM
Trueburton's Avatar
Trueburton
its' an 87 f150, 4x4, manual trans.
Old Feb 7, 2005 | 05:39 PM
bhartman78's Avatar
bhartman78
87 f150?
Are you talking about the module that controls the wipers working or the pump that moves the washer fluid? After your answer, I maybe can give you an answer.
Old Feb 7, 2005 | 08:15 PM
Franklin2's Avatar
Franklin2
Here is a wiring diagram for the wipers.
http://www.autozone.com/images/cds/g...3d800a3a5b.gif
I would try putting 12 volts on the white wire, and then try to put 12 volts on the darkblue/orange, to see what each does. I am afraid if you wire it up to a toggle switch this way, they won't park at the bottom like they are supposed to though.
Old Feb 7, 2005 | 09:43 PM
Trueburton's Avatar
Trueburton
actually neither the fluid or the wipers work but right now i need to get the wipers working. The wiring diagram wasn't the right thing either.
Thanks for the help so far hopefully we can figure this out.
Old Feb 7, 2005 | 10:29 PM
Franklin2's Avatar
Franklin2
Those wiring colors in the lower right corner of the diagram don't match yours?
Old Feb 9, 2005 | 07:43 AM
Trueburton's Avatar
Trueburton
i couldn't even get to the diagram you were talking about. Was i supposed to click on the hyperlink? Cause i did and it didn't bring me to a wirring diagram.
Old Feb 9, 2005 | 07:45 AM
Trueburton's Avatar
Trueburton
nevermind i figured out where the diagramm was. Thanks i will try to play around with it this weekend.
G. O. Mann
Jun 13, 2017 11:35 AM
warren561
Feb 4, 2016 08:42 AM
jstsumgi
Sep 14, 2015 08:57 AM
84-250
Electrical Systems/Wiring
Aug 7, 2005 03:54 PM
Rmcmorris
Aerostar
Apr 10, 2003 11:21 AM
