Oil & Lubrication
Differential Lube
Old Feb 5, 2005 | 01:05 AM
1984 f-250's Avatar
1984 f-250
Differential Lube
I had my rear differential changed at jiffy lube and i read that limited slips need a friction modifier added. Does jiffy lube automaticly add it or is it not needed?
Old Feb 5, 2005 | 07:41 AM
scionti 94's Avatar
scionti 94
It does need it and if your invoice doesn't show an additional charge for the additive, they probably didn't do it.
Old Feb 5, 2005 | 09:03 AM
superrangerman2002's Avatar
superrangerman2002
If you have a LS rear end, then you need the additive (depending on the oil they used). If you do not have a LS rear end, then the additive is not needed.
Old Feb 5, 2005 | 11:13 AM
Rockledge's Avatar
Rockledge
If your not getting any rearend "chatter" when going around turns on dry pavement, then I would hold off on putting in any more additive. Supposedly the Valvolone Durablend that (I'm assuming) they put in your truck's diff already contains the additive, however it's mostly a matter of degree. In other words, how much additive is needed depends on the condition of the clutch packs of each LS diff.
You actually want to use as little of the additive as necessary, since it's purpose is to reduce the limited slip characteristics of the rearend. Only use enough to make chatter go away.
Old Feb 5, 2005 | 08:11 PM
1984 f-250's Avatar
1984 f-250
Thanks for all the help!
rsylvstr
Oil & Lubrication
16
Mar 11, 2007 10:43 AM
tjsker
Jul 12, 2006 04:24 PM
fordtruckin
Feb 1, 2005 12:38 AM
Spindeepster
Sep 7, 2004 09:35 AM
kev100
Mar 13, 2003 07:13 PM
