Offroad & 4x4
sway bar links
Old Feb 3, 2005 | 06:58 PM
Chris_ce's Avatar
Chris_ce
sway bar links
Anybody make quick disconnects for their sway bars. My front ones are shapped like a u and I think I could remove a bolt and put in a pin the type that has the ring that folds over the pin. What about the rear. The end of it looks like a stud kind of like the top stud for a shock. What could be done with that?
Old Feb 3, 2005 | 07:43 PM
ivanribic's Avatar
ivanribic
The tough thing with making a quick disconnect for the stock bars is you have no way to get them up out of the way. They end up smacking the axle as it cycles. I've looked at a few custom sway bar designs that allow a lot of travel and can be disconnected and tied back but I just decided the easiest way to do this was to pull the whole damn sway bar.
Old Feb 3, 2005 | 10:28 PM
fishmanndotcom's Avatar
fishmanndotcom
you might as well pull the rear sway bar off! i have found that it doesn't aid much. as for the front that is possible and what you are referring to is a lynch pin found at any hardware store or more likely at a tractor supply store. but like ivan said i pulled mine off too and haven't looked back (yes even for my DD as well as my tow rig)
-cutts-
Old Feb 4, 2005 | 06:44 PM
Chris_ce's Avatar
Chris_ce
Well I looked at them today.Thanks Ivan your right they will hit. The only other thing I can think for the front is if I found some type of sleeve to slip over a staight part then have the lynch pin where the bolt goes that way I could take out a longer peice so as not to hit anything. Would I weaken the bar to much if I drillied a 1/4in hole for some type of pin to hold the sleeve so it doesn't move? The rear hasn't been hooked up for a long time now so thats no problem.
Old Feb 4, 2005 | 07:02 PM
monsterbaby's Avatar
monsterbaby
sway bars? what are they? you must mean that piece of steel that I took out, and tossed into the scrap iron pile
Old Feb 4, 2005 | 07:26 PM
Chris_ce's Avatar
Chris_ce
Gotta have it for dodging the people at the mall.
I drive it more on the road than in the mud just trying to make all around good 4x4.
Old Feb 4, 2005 | 07:30 PM
monsterbaby
if they're slow enough you have to dodge them then they are worth more points
Old Feb 5, 2005 | 12:36 PM
2classics's Avatar
2classics
Took mine off and haven't noticed. I think 3/4 ton springs are stiff enough
Old Feb 6, 2005 | 08:57 PM
fishmanndotcom
not at all and i think that is an awesome idea! ir should work although getting the bars to line up everytime could prove to be a bit of a chore!
-cutts-
Old Feb 7, 2005 | 10:58 AM
ivanribic's Avatar
ivanribic
With adequate lift and big enough tires you don't need to dodge ANYTHING at the mall . . . trust me. Right over the top of them works out fine.
Old Feb 7, 2005 | 07:25 PM
Chris_ce's Avatar
Chris_ce
Are you kidding I live in a punk infested sue happy college town.
brian42
Jul 8, 2024 02:00 PM
DDDDDMorgan
Oct 4, 2016 01:57 PM
H1449-6
Apr 25, 2009 06:57 AM
atillett
Mar 14, 2008 07:56 AM
UncleBob75
Oct 13, 2003 12:21 PM
