not only will it not hurt it.... it will help it. it'll keep the front hubs greased up but won't bind the t-case on the pavement. when it rains a lot here i leave my front hubs locked and t-case in 2wd, that way when i find some real soft stuff i can just hit 4x4 instead of having to jump out everytime.
Makes sense. After 15+ years of wheeling, I never thought of that. Also, you won't get into a situation where you get stuck, then have to get out, lock the hubs, and pray you make it out....
anytime anytime.... that's what i try to do here other than flame folks is to help
hey bulrydr_1... where are you from in GA? i live in Fayetteville about 45 mins south of Hartsfield! lemme know if you wanna go wheel sometime!
-cutts-
i'm originaly from Oconne county, you can either hit 316 or 78 towards Athens, and pass through my old stompin grounds! Right now I live in south Carolina, because the Air Force tells me to. I do get home quite a bit though....
