crower cam
Old Feb 3, 2005 | 05:24 PM
jethro bodine's Avatar
jethro bodine
crower cam
does anyone know if a cam with 228-230, 566-587, would be to much for a 390 with trw 2291 pistons, edlebrock RPM mainfold, not planning on doing anything else to motor.
Old Feb 5, 2005 | 08:25 AM
Six Niner's Avatar
Six Niner
it would probably be to much for the stock valvetrain components.
Old Feb 5, 2005 | 02:13 PM
rusty70f100's Avatar
rusty70f100
I do know you wont be able to get away with the stock valve stem seals. I'm running the Crane 343941, which has .533" / .563" lift, and on the exhaust side the valve stem seals very nearly hit the spring retainer / cap thing at full lift. I think the clearance was about .000". You'd probably have to put aftermarket teflon seals in.
Old Feb 5, 2005 | 04:46 PM
fordeverpower's Avatar
fordeverpower
I 'm guessing your truck is 2wd. But imo that cam should be run with headers, and modifed heads. I really think the 16241 cam would be a better choice.
16242
284/290
226/230
112 ls
1.73 ratio lift
.554/.573
recommended springs #68340, dual, 119lbs at 1.900, 359lbs at 1.350.
16241
280/286
222/228
112 ls
1.73 ratio lift
.528/.542
recommended springs #63302x1, single, 91lbs at 1.850, 256lbs at 1.350
thecowboy
Aug 25, 2004 10:49 PM
bronco cam
1978 - 1996 Big Bronco
Dec 25, 2002 09:49 AM
William
Dec 4, 2002 09:47 PM
GT40man
Jun 15, 2002 03:45 PM
TallPaul
Sep 18, 2001 12:04 AM
