Sponsored by: Auxito
Intermittent fuel pump failure
Old Mar 28, 2004 | 07:16 PM
Smokeythebear's Avatar
Smokeythebear
Smile Intermittent fuel pump failure
I have a 1999 F150 small V8 with an intermittent fuel pump failure.. Recently when the ignition switch is quickly turned from off to start, the engine will crank but no fuel. If the switch is turned from off to run, the fuel pump will run for a couple of seconds then will start when the switch is forwarded to the start position. Again this problem is intermittent and on occasion if the system fails on the first try, the vehicle must set for a half hour or so before the fuel pump will run even with the switch in the on position. Any ideas on the cause of this type of failure? Thanks.
Old Mar 28, 2004 | 10:58 PM
LxMan1's Avatar
LxMan1
Bad fuel pump relay?
Old Jul 17, 2010 | 12:23 PM
jackbob's Avatar
jackbob
Hey Smokie,
I have the same issue. Did you get it resolved?
darkstar8
Jun 2, 2021 10:47 PM
Blueman2
Nov 26, 2011 12:17 PM
drjoe171
Sep 20, 2010 06:04 PM
seedpress
1978 - 1996 Big Bronco
Sep 9, 2010 09:48 PM
brandomcg
Jul 20, 2010 08:45 PM
