EDM machining- how does it work?
Old Feb 2, 2005 | 07:49 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Question EDM machining- how does it work?
I need an explanation of how EDM machining works. I think it uses an energized brass wire to cut very hard alloys. Is this a CNC only process? Is this limited to what a jigsaw or plasma cutter could do? Can it make blind holes? Does the work piece have to be grounded? Is it like arc-gouging? And about 10,000 other questions...... Any info or references would be great. Thanks
Old Feb 2, 2005 | 08:02 PM
FTE Herman's Avatar
FTE Herman
This you do it for you, I would explain it myself but I'm tired of typing.
http://en.wikipedia.org/wiki/Electri...arge_machining
Old Feb 3, 2005 | 12:44 AM
ckrichard's Avatar
ckrichard
Here is another website that explains about EDM.
http://www.jjjtrain.com/vms/other_edm_basics.html
If you click on libary, they have lots of information about machining.
Chris
Old Feb 3, 2005 | 04:59 PM
FLgargoyle's Avatar
FLgargoyle
Forget all that; it's magic! I put my pointy hat with the stars on, and run one almost every day.... They're right, it's too much typing. Casually, I tell people it's welding in reverse. It has to do with the spark actually melting tiny particles of the steel, which are then flushed away with some kind of dielectric fluid. There is wire and plunge. Plunge involves an electrode shaped to the form you want to burn. Happy reading!
Old Feb 3, 2005 | 05:59 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
That is what I needed to find out. Thanks for the replies.
6CylBill
18
Mar 11, 2010 01:21 PM
tseekins
22
Aug 17, 2009 10:11 PM
e1p1
30
Feb 4, 2008 01:24 PM
Autoglass
29
Dec 21, 2007 09:38 PM
triton_2002
Apr 7, 2005 08:17 AM
