CPS vs Crankshaft Sensor
Old Feb 2, 2005 | 01:57 PM
rost495's Avatar
rost495
I had a couple of misses under power on my PSD. I was thinking if it keeps happening and is not solved once I fix my oil leak(still waiting on orings.....-- QUICK-- need the HX mod info and ya didn't answer my email --help on that please!!) that I should replace the CPS. Was talking to a mechanic that thought it might be more likely the crankshaft sensor???
Any thoughts or input?
Thanks, Jeff
Old Feb 2, 2005 | 02:41 PM
KC0FHM's Avatar
KC0FHM
crankshaft sensor amd Cps are the samet thing and there's only one of them thank god (and the designers
Old Feb 2, 2005 | 03:23 PM
tex1313's Avatar
tex1313
Easy to replace. 10mm socket with extension and you've got it. Found it the easiest at the stealership. Wasn't that much more expensive than Autozone, O'Reilys, etc. My '99 started dying at idle when the CPS first started to go. Then it would die going down the highway and restart itself. That's no fun at all!!!!!!!! Good luck
tex1313
Old Feb 2, 2005 | 05:14 PM
ckal704's Avatar
ckal704
Can someone explain the exact function of the CPS? The service mgr. where my truck is undergoing surgery explained it as a sort of "warning device" that serves to shut down the engine when something else is going wrong.
I was kind of under the impression that it basically kept all the other systems informed as to where the engine was in the timing circle at all times so fuel could be injected, etc.
psd96
15
Nov 28, 2024 11:42 PM
okla82bronco
Jul 30, 2017 05:33 AM
hdman6
Escape & Escape Hybrid
Nov 29, 2011 07:54 AM
lylino
Aug 15, 2009 02:12 PM
wajah2
Aug 19, 2005 07:34 PM
