Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Crankshaft position sensor help
Old Aug 12, 2009 | 05:36 PM
lylino's Avatar
lylino
I ran the codes at Autozone and it says I need a new CPS. The mechanic I know says that could just be the beginning. What else usually goes wrong with that?
Old Aug 13, 2009 | 08:00 AM
budwich's Avatar
budwich
AFAIK, there are no codes that say "need a new CPS". Codes all indicate conditions or readings. That's the reason for the mechanic's statement.... a reading doesn't necessarily mean "need a new CPS". IF you post the actual codes here, someone might be able to help add further "meat" to this story.
Old Aug 15, 2009 | 02:12 PM
aquanaut20's Avatar
aquanaut20
Most CPS related problems can be fixed by cleaning the CPS plug and filling sockets with dielectric grease. They get wet and corrode, causing resistance, and sending a poor signal to the ECU.
Kingranch2011
New Member Introductions
Jun 26, 2014 11:46 AM
ncalf150
May 20, 2014 10:59 PM
Vinford
May 7, 2014 05:56 AM
Hankster1958
21
Oct 13, 2013 12:36 AM
171
Nov 27, 2011 08:03 PM
