Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
cps sensor location 2002
Old Nov 25, 2011 | 11:45 AM
hdman6's Avatar
hdman6
Question cps sensor location 2002
i have a 2002 escape 6 cyl. i believe the cps is acting up because it is stalling at idle with no codes. I replace the mass air flow sensor already. I had this happen on my 7.3 diesel and it is always the cps sensor. I just need to find out where it is located on the escape so i can replace it. thanks jeff
Old Nov 25, 2011 | 05:29 PM
F100classics's Avatar
F100classics
I would look into the IAC before the cam sensor. Stalling and hard starting would point towards fuel and air controls. Many times no codes will show with a bad IAC and a TPS would be my next guess.
Old Nov 25, 2011 | 06:14 PM
hdman6's Avatar
hdman6
i just replace the IAC last month. It was stalling when in reverse. I replaced the IAC and it stopped until now. So maybe ill go after the TPS next. Of course not throwing any code makes it a little harder to figure. its still cheaper than taking it in to the stealer for now. Ill double check the IAC seal as well. thanks Jeff M.
Old Nov 25, 2011 | 06:34 PM
hdman6's Avatar
hdman6
Thumbs up
Update.. I just talked to my wife about what thher Escape has been acting like. Looks like the TPS after all. The gas pedal is not responding and lagging etc. Thanks for the help Jeff
Old Nov 29, 2011 | 07:54 AM
cat-977's Avatar
cat-977
ya I would say IAC motor too
Camper1
Jul 8, 2007 10:24 AM
Ghost24
Dec 23, 2005 09:12 PM
colemanhill
15
Nov 13, 2005 01:15 PM
Hi-psi
Aug 26, 2005 11:55 AM
lostbuckaroo
Mar 29, 2004 12:23 PM
