Sponsored by: Innova
Sub Grounding
Old Feb 2, 2005 | 08:16 AM
DoofusOfTheDay's Avatar
DoofusOfTheDay
Sub Grounding
This is probably an easy question for those that have more electrical knowledge than me, which is a lot of you. The harness that came with my sub has about a 14 or 12 gauge wire coming off it for the ground connection. I am told by one guy I work with that it would be worthwhile to solder a small length of heavy gauge(I have some 6 gauge) wire to the smaller wire and then attach the heavier gauge to the body of the truck.
I understand a little about resistance and why you don't use a 1000 foot 14 gauge extension cord to run your table saw, but don't understand how I would be gaining anything by adding short length of heavier gauge wire prior to attaching to truck body.
Old Feb 2, 2005 | 05:26 PM
danger_ranger_dude's Avatar
danger_ranger_dude
That doesnt make all that much sense, shortening the wire would be good because it wouldnt put as much resistance against the amp, and will help its performance. You already have short wire going from the sub so changing it after the fact would be useless, also most wiring kits have the proper guage wire, so that shouldnt be a problem.
Old Feb 2, 2005 | 07:03 PM
bigjace8's Avatar
bigjace8
the ground from the sub should go directly to the amp and no where else i would not ground the sub to the vehicle. now for the ground from the amp i would stick w/1 size wire from the amp to the vehicle chasis
Old Feb 2, 2005 | 07:26 PM
Blinky22's Avatar
Blinky22
The question that needs to be asked is what kind of sub are you installing?
Is it just a sub (speaker) or is it a sub, box and amplifier all in one like
an amplified base tube?
If it is just a sub (not amplified) both the + and – will have to be connected to a amp
If it is a amplified sub and box then the provided wiring should be more than sufficient to do the job required
Old Feb 3, 2005 | 04:05 AM
DoofusOfTheDay
It is self powered sub. I am going to take the supplied ground wire and attach it to truck body and be done with it. Thanks.
Brownrp92
17
Dec 9, 2016 06:53 AM
BigCountry1978
17
Jul 5, 2016 12:43 AM
Haywire-Powerstroke
May 10, 2016 10:12 AM
BGF100
Nov 13, 2015 08:14 PM
rd400f
Feb 10, 2013 09:39 AM
