Front-end Thump during braking
Old Feb 1, 2005 | 10:58 AM
strangmk's Avatar
strangmk
I have a 2001 F250 7.3L 4X4 CC. During braking I will hear 1 thump coming from under the driver's side floor board. I don't think it happens during turning. Experts....I'm asking.
Old Feb 1, 2005 | 11:06 AM
CHAD250CC4X4's Avatar
CHAD250CC4X4
I also have been having this problem. couldn't find anything loose when i took the wheel off and looked.
Old Feb 1, 2005 | 11:29 AM
tjbeggs's Avatar
tjbeggs
your ball joints are probably very bad. jack your truck up and grab your tires at 12 and 6 and push in and out. you will know when you have a problem
Old Feb 1, 2005 | 01:50 PM
CHAD250CC4X4
I did that and nothing.
Old Feb 2, 2005 | 10:25 AM
k2vailkid's Avatar
k2vailkid
If the ball joints are eliminated as a problem, the only other thing that comes to mind would be loose caliper bolts. I've seen this on other vehicles from time to time, just a thought.
Old Apr 8, 2005 | 03:40 AM
touchofgrey's Avatar
touchofgrey
If this is only happening while your braking.....and your feeling a thump under your feet. Here's a couple of things to check. If you look in your maintenance manual....around 100k. Ford states that on 4x4s the U bolts should be checked for looseness. I think they state to take them to 120 ft.lbs......something like that. Also, you might want to look at the torsion bar links that connect from the bar up to the frame on both sides. Sometimes the bushings give way, and you will feel them take up the slack when you brake.
Old Apr 8, 2005 | 08:12 AM
csramsey640's Avatar
csramsey640
also ck your shock
TampaDave
Dec 19, 2010 11:16 AM
tebby
Jun 17, 2008 11:21 AM
DIeselmanRI
2004 - 2008 F150
27
Apr 16, 2006 09:24 AM
vikin11
1983 - 2012 Ranger & B-Series
Nov 13, 2004 03:02 PM
Monsta
May 17, 2002 09:28 AM
