Front End Noise
Old Dec 18, 2010 | 12:41 PM
TampaDave's Avatar
TampaDave
Front End Noise
I hear a thump in the Driver's side front wheel of my F250 4x4, 125K miles. The thump occurs right before a the truck completely stops, not during the entire braking process.
I looked at the front end for visable worn out parts, and I did not see anything.
Any Ideas?
Old Dec 18, 2010 | 05:10 PM
JBSIXGUNS's Avatar
JBSIXGUNS
look at your tires, look for any unusual wear patterns (like scalloping) across the treads, when the shocks wear out it allows the tire to hop off the pavement and wear unevenly, and if your ball joints are bad the tire will wear worse on one side, (like the inside)
My truck acted like yours and it turned out to be my tires had worn very uneven due to needing shocks and ball joints,
Old Dec 18, 2010 | 05:13 PM
JBSIXGUNS's Avatar
JBSIXGUNS
you can check your ball joints for play by jacking up the tire and wiggling it like this, if it moves like this, its time for new ball joints
YouTube - I think it's time for new ball joints!
Old Dec 18, 2010 | 07:21 PM
TampaDave's Avatar
TampaDave
next question
If it is the ball joints, how hard are they to change??
THANK YOU ALL FOR THE QUICK REPLIES
Old Dec 19, 2010 | 11:10 AM
wallace32's Avatar
wallace32
Any Ideas?
I think I have the same issue. It happens to me after I've come to a complete stop. Just a low thump. I just recently had my ball joints replaced and I asked the guy who did the job to inspect the entire front end and he let me know that everything was ok except of course for the ball joints. I'm hoping it isn't a transmission issue.? Sorry I can't be of more help.
Old Dec 19, 2010 | 11:16 AM
wallace32's Avatar
wallace32
If you run a search through this site you can find the instructions on how to replace the ball joints and make a better decision on how hard it would be to replace them yourself. I mentioned I just had my replaced and when I was looking, it looked pretty intense. But then again, I'm not that mechanically inclined. The dealership quoted between 1200-1500. I took it to a shop that specialized in suspension, brakes, etc. and they honored a price of 605. I also had my tires rotated and balanced and it totaled about 650. Hope that helps.
christyj
20
Dec 15, 2014 11:33 AM
dutchnichols
Sep 26, 2014 09:29 PM
bandito
Dec 14, 2006 04:47 PM
JMACC
Jan 13, 2005 09:09 AM
dalton
1997 - 2003 F150
Nov 19, 2003 07:10 PM
