Exhaust in cab of 93 Explorer
Every now and then, while on the highway, the cab of my 93 Explorer fills up with smoke. Just had the AC unit replaced. Any idea as to what could be causing this to happen? I'd like to arrive not smelling like the inside of an exhaust pipe. I've searched the forums for someone else who may have had a similar problem, but I couldn't come up with any solution specifically for an Exlporer.
The vents meen that either then fan motor is shot, or there are leaves/pine neadles in the fan that are causing it to smoke. To fix the problem pull the fan motor out and see if it is hard to turn and/or there is a bunch of junk inside of it. The fan motor is located to all the way to the passenger side on the fire wall.
The exhaust system is fine.
Chris
Chris
Thanks so much for your posting ckrichard. We park the car outside under the trees and the smell/smoke from the vents sometimes tends to smell like burning leaves. We'll pull the fan out this weekend and take a look. I'll post back to let you know if we were successful. I'm relieved it isn't the muffler.
masterson32
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-17-2009 01:45 PM
Tyrone7000
07-14-2005 07:35 PM
