Hey guys, I have an engine code P0430. Auto Zone printed out the code and reads "the PCM has determined that the catalyst system efficiency for Bank 2 is below threshold for the current engine operation condition". I looked up the code in my Ford CD manual and found numerous possiblities. One of the possibilities could be 02 sensor or downstream O2 sensor wiring. I want to replace all O2 sensor, according to the manual theres only 2 O2 sensor but Auto Zone says there are 4. Who is right? At $60 a sensor, I want to buy what I need. Please guide me to into the right direction. Thanks 99 eddie bauer expy 5.4
There are 4, two aft of the exhaust manifold and two aft of the cats. Get yourself and $11 Haynes manual from Autozone, it will benefit you greatly and has the codes in it. I don't know what yr you have, but it sounds like a possible clogged cat.
