2000 expy fire
Old Jan 30, 2005 | 11:47 PM
02expedition's Avatar
02expedition
Exclamation 2000 expy fire
I am actaully a mechanic and for the past 5 years and I have never saw anything like it in my life.... My boss was working on a 2000 expedition at our shop last summer and when he got done working on it he put it outside. The truck was in for a rough idle and one of the kids that works next door to us came running in my shop and said is that ur expedition on fire out there I was like hahaha (cause I own a 02 expedition) until I got to the door...looked out...and saw a blazing inferno the whole truck was ingulfed in flames but it wasnt mine (thank god) then the gas hit then boooom not a pretty site so all that I am saying is get that cc looked at people!
Old Jan 31, 2005 | 10:33 AM
buzzard's Avatar
buzzard
So he (boss) had finished driving it withe the cruise control on?
Old Jan 31, 2005 | 01:36 PM
NoMo's Avatar
NoMo
From what I understand, the CC doesn't have to be "on" for the switch to get power, overheat & subsequently ignite. Seems it has power even when the vehicle is off.
Old Mar 18, 2005 | 10:56 AM
351V8's Avatar
351V8
WOW!!!!!!!!!!!!! is there a recall letter is ford doing anything about it?? Can this happen to earlier expedtion as 1999??
Wondering????
Old Mar 18, 2005 | 11:27 AM
pitrow's Avatar
pitrow
The recall is only on 2000 model year F150, Expedition, Navigator and 2001 F-150 SuperCrew trucks with factory equipped speed control.
However, those of you unlucky enough to have one under recall may have problems getting it replaced. I found this on blueovalnews.com...
"Ford Motor Company told dealers that the parts necessary to perform safety recall 05S28 will not be available in sufficient quantities until April or May of 2005"
http://www.blueovalnews.com/2005/adv...28.09mar05.htm
Good Luck!!!
Old Mar 18, 2005 | 03:02 PM
351V8's Avatar
351V8
Good Luck!!!
Thanks........... I wonder if I am safe!!! ??????????
Old Mar 18, 2005 | 04:08 PM
buzzard's Avatar
buzzard
Don't know:
http://abclocal.go.com/ktrk/news/031...l_suvfire.html
Old Mar 18, 2005 | 05:34 PM
kb-65's Avatar
kb-65
The problem switch is on the mastercylinder (under the hood). Just unplug the switch and tape the connector. this will cover you till the switches arrive. This is what the dealer will do. The cruise should still work as this a seconday redundant cruise cancel switch. It only works if the mechanical brake switch doesen't.
Old Mar 21, 2005 | 11:03 AM
351V8's Avatar
351V8
Originally Posted by buzzard
wow !!!!!!!!!!!!!!! I cannot belive it !!!! thank you !!...
Old Mar 21, 2005 | 11:05 AM
351V8's Avatar
351V8
kb 65,
Do you think I should call and make an appointment with dealer.. or just order a new one a replace it myself??
Thanks!!!
Ps, I can't believe that Ford has know about this for so many years!! class action law suit!!!
Old Mar 21, 2005 | 05:00 PM
kb-65's Avatar
kb-65
There are no parts available as far a I know. the dealer will disconnect and tape the connector. they wil let you know when the parts come in.
Old Mar 21, 2005 | 08:46 PM
FTE Herman's Avatar
FTE Herman
God, so much mis-information. If you DC the switch the CC is dead. And I don't think the gas tank caught and went 'boom'. Sheesh. There is truth in the statement that the circuit always carries current and if my information is correct, it is an unfused circuit. It is also true that it will be April/May before a sufficient supply of replacement parts are available. It aint gonna be the switch folks, same switch is used in many applications. It is thought that those vehicles in which the fires occurred the switch has a tiny amount of fluid leakage that sits in the switch, around the electrical contacts. A short circuit ensues and ignites this fluid and the fire spreads. The replacement is likely to be a plug-in harness that has an in-line fuse.
