Sponsored by: Real Truck
lift differences???
Old Feb 5, 2005 | 02:00 AM
sandrailer99's Avatar
sandrailer99
I have a 99 sd cc f350 and 305 70 16's tires . I want a 6" lift and 35 tires.Question is do i need a gear reduction to run larger tires?
Old Feb 5, 2005 | 02:06 AM
mattd17's Avatar
mattd17
sandrailer..... well no you do not NEED to change gears... but it really depends on what engine you have..... is it the v-10? i have the 5.4L, and i am going to run a 4.56 gear with 37's. i have heard a lot of people with the PSD say that its not an issue, the engine handles it well no matter what tires they run. good luck !
Old Feb 5, 2005 | 02:22 AM
sandrailer99
Smile
I have 7.3L psd . So it sounds like i dont need a reduction. thanks
Old Mar 14, 2005 | 04:47 PM
PurerockRacing's Avatar
PurerockRacing
what about the front? My truck is about 8" up, however the front is still about 1-2 " lower than the rear. There's 4 inch blocks under my rear springs, no blocks in the front, the springs are right down on the axle. Can I just add a 2" block to the front and get longer u-bolts?
Old Mar 14, 2005 | 06:17 PM
2000silverbullet's Avatar
2000silverbullet
Whatever you do, don't EVER put blocks in the front end (of ANYTHING). Big no no. You can either get new shackles up front to lift the front up, or drop the back by putting a smaller block in there.
jch66
Offroad & 4x4
Jan 31, 2013 01:43 PM
madmatt14
Sep 17, 2011 08:23 PM
74redone
2004 - 2008 F150
38
Aug 23, 2010 02:00 AM
Big Swole
Jun 27, 2007 08:04 PM
quadsand
Feb 2, 2005 10:06 AM
