Sponsored by: Real Truck
Lift Kit
Old Sep 16, 2011 | 10:49 PM
madmatt14's Avatar
madmatt14
Lift Kit
Hey guys i have an 02 superduty 5.4l extended cab in the process of lifting but need some help. So here goes. A majority of the lifts im finding say v10 diesel only whats the difference as far as the lift kit goes Im guessing weight but does it actually matter? 2nd is i want a 6" or 8" lift with new leafs on 37s my concern is driveshafts what should i be preparing for. any insight and if im in the wrong section point me in the right direction, new to the site, still learning
Old Sep 16, 2011 | 11:17 PM
robd928's Avatar
robd928
Welcome,
Most lifts are designed around the diesels but work fine on gassers. Expect to get more than the advertised lift on your 5.4.
I got an extra inch on my Icon lift and have seen some get more with other brands.
If you go 8 or more you'll have to get the front driveshaft lengthened and 6 or more you'll need longer brake lines.
Need anymore info feel free to pm me.
Rob
Old Sep 16, 2011 | 11:43 PM
madmatt14's Avatar
madmatt14
Thanks for the info. im guessing end result ill have to change the factory 2" blocks in the rear so it dont "sag"?
Old Sep 17, 2011 | 08:35 AM
robd928's Avatar
robd928
That'll depend on the brand of lift you choose. Some use your factory block and you stack theirs to raise up the rear others use a single replacement like Icon.
When I ordered my 4in lift from Icon I substituted the 4 inch block for their 5 inch and the rear sits 1/2 inch higher than the front. But that was after talking to the guys at Icon. If I'd have left the 4 inch block the truck would have sagged.
Rob
Old Sep 17, 2011 | 03:44 PM
7fords's Avatar
7fords
most lifts will settle some after awhile. usually about 1/2 inch
Old Sep 17, 2011 | 03:49 PM
Fordfanatic4life's Avatar
Fordfanatic4life
keep in mind a "deisel" specific lift kit for your truck will ride a bunch stiffer then the same kit designed for your 5.4 equipped truck..
the spring rate is designed to tame the extra weight of the deisel engine you dont have.
Old Sep 17, 2011 | 07:44 PM
Joe Bloomingdale's Avatar
Joe Bloomingdale
This is my F-250 with a 6 1/2" Pro Comp all spring lift, I went with a 4" rear factory block so I didn't have to stack them. It is a V-10 but the front spring packs had a spacer at the bottom to remove with a 5.4. Besides the front usually sags more than the rear anyway.
Old Sep 17, 2011 | 08:23 PM
hotroddsl's Avatar
hotroddsl
^great looking truck Joe^ Monty would be proud to ride with his head out that window and slobber down the side!
Jim & fat Monty
F-250 6.2L
Aug 31, 2015 09:32 AM
sitInHigh
Sep 8, 2013 05:04 PM
shore
Feb 14, 2009 05:44 PM
k7ikuzus1k
Dec 18, 2007 02:18 PM
powerstroker88
Aug 6, 2007 12:20 PM
