Battery cable size question?
Old Jan 30, 2005 | 12:32 PM
Arnold Kenyon's Avatar
Arnold Kenyon
What gauge of cable or brand would be best for replacement battery cables and starter cable. I have a 1979 F150 with a 460 auto that slow cranks when it is hot. I checked all the connections and found a bad starter cable. I have searched this forum and have seen talk about going to a welding shop and having them build "heavy duty" cables but no specifics on gauge of cable or anything. I thought while I was at it I would replace the battery cables as well.
Old Jan 30, 2005 | 01:21 PM
MemOrex's Avatar
MemOrex
I used 4 gauge when I relpaced my wires. Works fine.
Old Jan 30, 2005 | 02:02 PM
Franklin2's Avatar
Franklin2
For a normal stock application, 4 guage should be more than enough. And you should be able to get these stock at the parts store.
Old Feb 11, 2005 | 06:52 AM
grn150's Avatar
grn150
Thumbs up Welding Wire
I replaced all of my battery and starter cables with Neoprene coated 1/0 welding wire with brass terminal ends (about 50 bucks total). I needed to go to a welding supply store to get them to crimp on the ends. They work great. My 1978 F-150 has a 460, and it had hot starting problems. With those cables, a 140 amp Powermaster alternator, new starter, Optima red top, and a new voltage regulator, it always starts right up. Also, try wrapping your starter with some insulation. There are a lot of companies that offer starter shaped wraps with crimps to secure them.
I have heard a lot of hot start problems, and it seems to be related to heat soaking the ignition module (gray box), and the starter. Good luck!
Old Feb 11, 2005 | 08:45 AM
Arnold Kenyon
grn150
Where did you find the wire and connectors?
Old Feb 11, 2005 | 12:39 PM
Franklin2's Avatar
Franklin2
I needed to go to a welding supply store.......
I have seen large cable and connectors sold on ebay too. There is a guy with an ebay store that sells that stuff.
Old Mar 2, 2005 | 01:09 AM
popsbronco's Avatar
popsbronco
I replaced my starter stap neg and pos cable with 1 gauge on my 74 brronco
worked great.Knows strarts better when hot.
IUsed a 34 inc battery cable and cut the end off and soldered on a crimp type copper terminal.
Got it all and a parts store for about 50.00
i will be looking into geting some heat sheilding for my starter just the same .Sound like a good idea
Cheers
Old Mar 3, 2005 | 07:31 PM
rebocardo's Avatar
rebocardo
You can go to West Marine and have them use any size wire (1/0 to 4 guage) and crimp on lug ends for you. While there you can pick up marine terminals too.
I bought my 4 guage and marine terminals at NAPA and crimped my ends in a vise, that had teeth, using a cheater bar. I coated the ends with di-electric grease before crimping. The Marine cable at West Marine is basically tin coated and very nice.
I usually run a 4 guage to the block, 6 guage to frame, alternator bracket, firewall, and radiator support. Then a 12 guage to the voltage regulator case.
ligito
Apr 10, 2015 08:00 PM
78 & 87 Super Cab
May 20, 2014 04:27 PM
Frankiea87
Dec 26, 2013 04:40 PM
Hybris
1997 - 2003 F150
Dec 19, 2012 06:56 PM
Stangfire
1997 - 2003 F150
May 27, 2011 07:31 AM
