56 vs 53 Cab Skirt
56 vs 53 Cab Skirt
I have all the hardware to convert my 53 cab skirt to the 56 style. Bought stuff from Mid-Fifty and I think it is stock style? What's the best hardware to attach the skirt to the lip on the bottom of the cab, and the rubber to the hanger? I'm in the process of grinding mine off today. Screws or clips to mount. Doesn't have to be stock, though I am curious how it was attached by Ford. Want it to look neat from the outside.
dwayne-
On my 56 the rubber was originally stapled to the metal and the metal was held on with sheet metal screws. When I replaced it I used SS button head screws with nuts and attached the rubber with the push-on black plastic fasteners you find at body shop supply stores. Resemble a screw but they have a one-way serrated edge. That probably doesn't make sense and I can't recall what they are called but it worked pretty well. You set the metal strips so that the rubber falls behind the running board.
56FUN
56FUN
Thanks, I'll probably use similar hardware, but I am still not sure of the orientation. L and R can definitely be installed on either side by merely flipping it over. One way is obviously going to be upside down. I don't want some stocker nutcase like George climbing under my truck and deducting points.
relentless f100
08-12-2014 07:13 AM
Blown 331
02-25-2006 03:32 PM
