How do I remove temperature adjustment wire?????
Old Jun 24, 2002 | 12:56 PM
Wilber15's Avatar
Wilber15
[updated:LAST EDITED ON 24-Jun-02 AT 01:56 PM (EST)]If it ain't broke.....change stuff till it is!
My wire running from the back of the Hot/Cold adjustment lever broke last winter, and i wanted to fix it. I tore apart the dash and found the little rod that it connects to right behind the second passenger air vent. I was wondering if i was suppose to take the whole rod out with the wire when i replace it, or if the wire just slips off. I tried to slide the wire off the little rod thing and it didn't come. I didn't want to force it and break something. Could anyone please explain the procedure to change that adjustment wire. thanx....
Old Jun 24, 2002 | 08:01 PM
topo4u2's Avatar
topo4u2
Hi Wilber,
From what I can recall some of them have a small speed nut which justs holds the wire down onto the lever. If you are careful and can get at it you can use a small pair of pliers or needlenose to pull off the clip and then slide off the wire from the lever. I'm hoping that it is the style that I think or I will be wrong. Some do have small screws that hold them in but I'm not positive if this is your case. I hope I have helped and if not maybe you could describe it a bit more.
Old Jun 24, 2002 | 09:10 PM
canadianfordman's Avatar
canadianfordman
FordNFishinLover
33
Mar 24, 2010 04:04 PM
64F-100
Apr 5, 2008 10:43 AM
rlester
Feb 14, 2008 07:44 PM
viperbluelx
Jan 16, 2008 01:08 PM
fordrule13
1997 - 2003 F150
Mar 8, 2004 08:45 AM
