Temp guage not working
Old Jan 27, 2005 | 07:50 PM
bh2112's Avatar
bh2112
When i put a test light to the water temp. sending unit wire the light in the test light pulses. Should it be a solid light or should it pulse?
Old Jan 27, 2005 | 08:19 PM
Mil1ion's Avatar
Mil1ion
Pulse 5 volts.
How the gauge reads is determined by how often the pulse is.
This voltage is sent via a Instrument cluster Voltage Regulator attached to the back of the cluster.
Old Jan 27, 2005 | 08:42 PM
zwinstead's Avatar
zwinstead
Ground the wire that hooks to the sending unit and the gauge should read way over towards the hot side. If not the problem is in the wiring/cluster/gauge. If it does most likely you have an issue with the sending unit.
Old Jan 27, 2005 | 09:48 PM
bh2112's Avatar
bh2112
When i used the test light i looked at the temp guage and it only went up to about the cold when it is hooked up to the sending unit the needle stays at rest.
Old Jan 27, 2005 | 10:04 PM
zwinstead's Avatar
zwinstead
i think that means your gauge and wiring are good go buy a sending unit and try it they are only about $5-$10 bucks i think
Old Jan 27, 2005 | 10:52 PM
Mil1ion's Avatar
Mil1ion
Now you mention the gauge
I thought the concern was the pulsing current ?
Under what circumstance did this gauge read this.( Engine Hot,cold ,etc)
Make sure there isn't a whole bunch of teflon tape on the threads.
Some tape causes continuity problems.
The measuring is done by GROUND OUT of the S/U.
If it can ground out properly it won't read very high.
With the key on and the wire to the S/U directly to ground...what did the gauge do ?
Save your money for now on an S/U.
ps, Find a sealant that is made for sending units.
I think Permatex is one.
Old Jan 28, 2005 | 01:09 PM
John24255's Avatar
John24255
I have a 79 F150, with the same problem. As was said before, the best way to issolate the proplem is to unplug the wire to the temp sensor and ground it. While doing so, have someone watch the meter, perferable some cute young thing. Not that it makes a difference on the reading, it just makes test that much more fun. Hey, you may want to check that out a few times.
Anyway, if the temp gage heads for hot, the wiring and gage are good, the sensor neews to be replaced. I just purchased one at the local Autozone for $17. If you find somewhere cheaper please let me know.
From the looks of it, you may have to remove the fan, and alternator bracket to get it in and out.
John24255
Old Jan 28, 2005 | 10:07 PM
bh2112's Avatar
bh2112
I got it to work thank you for everyones input it was the sending unit i thought it was that but i just wanted to find out about the pulsing mostly.and sorry for the spelling of gauge i need to pull my head out.
oft
Oct 20, 2014 05:30 PM
clman
Nov 16, 2012 12:49 PM
Slip ford man
Aug 12, 2011 05:43 PM
TheMonkey
Sep 6, 2008 02:23 PM
ponypuffprincess
Aerostar
Jan 7, 2003 09:56 PM
