shifter wont move
Old Jan 27, 2005 | 03:56 PM
rocketman77's Avatar
rocketman77
shifter wont move
When I went to start my 1990 Ford F-150 half ton automatic, 5 litere the key turned to the start position really easy as if the spring in the tumlber had broken. I was able to start the truck however I then couldn't move the shifter arm out of the park posision. I therefore have a truck that runs realy good but won't go zoom zoom down the highway. Could the fix be as easy as replacing the ignition key mechanism or is it something more serious? Thanks bob.
Old Jan 27, 2005 | 04:35 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Bob...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 27, 2005 | 06:35 PM
tex94F250's Avatar
tex94F250
There is an ignition interlock that could be an issue and a pin behind the lock core that will cause problems. The interlock with the brake pedal may be at issue? Check those first.
Tex
michaelskerrett
Jun 25, 2014 11:18 AM
Action410
Jan 18, 2013 07:40 PM
Totally Tuna
Nov 30, 2008 02:44 AM
Slopitch
Sep 13, 2008 12:36 PM
fludoc
May 29, 2008 03:08 PM
