heated air box
Old Jan 25, 2005 | 09:43 PM
good 'ol ford's Avatar
good 'ol ford
heated air box
hey i plan on making a new airbox for my tuck and was wondering what parts i would need to make it heated. what all goes into one and where can i get the parts and whatnot. any ifno would be great
thanx
Old Jan 26, 2005 | 06:32 PM
good 'ol ford
aww com'on guys someone has to have done this b4
Old Jan 26, 2005 | 11:40 PM
beeboy's Avatar
beeboy
what do you mean by air box? Not the air cleaner housing?
good looking ride ya got there too!
Check out the NW forum when you get a chance!
Old Jan 26, 2005 | 11:54 PM
good 'ol ford
well yeah. ok let me explain my self alittle more. i want to replace my "trailer queen" breather with a box that sits on top of the carb. from that i want to run 2 intake hoses to the front of the motor on either side of the rad. and put k&n fillters to the outside of the front wall. the prolblem is i want to try and run the "heated" intake style that will suck hot air off the manifold for warm up
hope this helps and hope someone knows how to do this
Old Jan 27, 2005 | 12:10 AM
beeboy's Avatar
beeboy
gotcha...
what I would do is get a dual snorkel air cleaner off a mustang and use it for parts. You can cannibalize the air diverters into your project.
Old Jan 27, 2005 | 12:12 AM
good 'ol ford
ok how do these things work how do they close and what not they need vac. right?
Old Jan 27, 2005 | 12:36 AM
beeboy's Avatar
beeboy
yeah, its like what the stock air cleaner has. Vacuum operated diverters, got a heat sensor thingie on it so it knows when to open up.
Old Jan 27, 2005 | 05:34 PM
good 'ol ford
where does the heat sensor go.
Old Jan 27, 2005 | 09:04 PM
beeboy's Avatar
beeboy
It is built into the air cleaner. the vacuum hoses go into the side of the air cleaner, where the thermal sensor is, then from there up to the vacuum diverter.
Old Jan 30, 2005 | 01:07 PM
forddytube's Avatar
forddytube
what engine do you have? my 69 torino 351w has the setup under the stock aircleaner snorkel with a heat sensetive flap and hooks up to a sheet metal heatsheild like thingy that bolts onto the mani bolts, so if you know of a junkyard close by find the aircleanr setup that sits perfect on your carb (clearance) then the mani part you could fabricate with a pair of tin snipps and some sheet metal, then the hookup hose can be made from washer /dryer hose. old chevy trucks have the setup you just gotta picture what you want and some measurements then go a huntin'. try to find photos on the net of mustangs with the hood open then you can get a refference to work from.
Old Jan 30, 2005 | 07:18 PM
good 'ol ford
well thats the thing i want to make my own box that sits on the carb and retrofit the parts to make it heated alls i need to do is find the parts and which ones i need
babybober
May 7, 2022 07:22 AM
Skalywag
25
Jun 14, 2020 02:43 PM
Towster
Oct 25, 2016 07:57 AM
Rick1960
Nov 8, 2015 09:18 PM
abrisebois
Aug 28, 2006 06:08 AM
