struggling
Old Jan 25, 2005 | 05:40 PM
dmusgravejr's Avatar
dmusgravejr
Red face struggling
I have a 2004 F150 STX SuperCab 4.6Liter Triton and have been having a problem.I have 67 thousand miles(hwy)with routine maintenace.For a few days,my truck has surged when i accelerate.It happens during a pass or getting on the freeway.It feels like you are pushing the pedal and letting off over and over untill you actually do let off the pedal.Has anyone had or heard of this problem.Or maybe im overlooking a routine maintenance?Please help!I love my truck.
Old Jan 25, 2005 | 06:47 PM
Blue Blooded's Avatar
Blue Blooded
I have the 5.4l. I had fluxuations during idle on rare occassion. It has to do w/ the PCM as the gas pedal is fly by wire. The dealer installed the latest program in mine and it seems to be fine now.My guess would be that you need a similar remedy.
Old Jan 25, 2005 | 08:42 PM
Aubrey3's Avatar
Aubrey3
I don't know if this is related ... but did you see this thread:
http://www.fordtrucks.com/forums/sho...d.php?t=335943
Also, How did you get 67k in one year??? WOW!!!
Old Jan 26, 2005 | 02:04 PM
dmusgravejr
commuting
Well I commute to Houston which is about 60miles one way.Ive heard of the pcm problem but only on 5.4s.Ill give it a try though,thanks.
Old Jan 26, 2005 | 02:17 PM
Cincy F150's Avatar
Cincy F150
Have you changed the fuel filter on your truck? It sounds like it may be dirty or have gotten some moisture from the winter fuel blend. A lot of times doing "routine maintenance" it gets skipped. On my '02 the FF was tucked in the drivers side frame rail. I suspect that it is the same with the '04 but I haven't noticed it when under the truck. It also takes special tools to change it out.
Old Jan 26, 2005 | 02:20 PM
dmusgravejr
Red face overlooked
You are right.Overlooked that.I forget my truck is a year old and the motor with the miles is three.If thats not it ,wont hurt to change anyhow.Thanks
1'stonraceday
Apr 29, 2014 01:51 PM
garydmundy
Dec 13, 2012 08:46 AM
jeffh
Feb 25, 2005 10:22 PM
MalcolmBurgess
Jun 12, 2001 02:02 PM
