Trailer brake controller wiring problem
Old Aug 14, 2009 | 09:13 PM
Aggie05's Avatar
Aggie05
92 ranger 2.3 liter
I recently bought a trailer brake controller to help stop a trailer i pull. Im having a problem figuring out where to hook up the red wire. ITs the wire that is suppose to splice into the cold side of the vehicles stop lamp switch.
My brake has a switch with 2 wires, one green, one green with red stripe.
My volt meter shows the green one to be hot all the time even with no key on, the other one gets 12 volts when the brake pedal is pushed in.
When i hooked the red wire from the controller to the wire that gets hot once the pedal is pressed it pops the inline fuse on the power cord.
The other wire is hot all the time so that wouldn't work?
The only other thing i can think of is to find the wire the feeds the tail lights, NEED HELP.
Old Aug 14, 2009 | 09:45 PM
aquanaut20's Avatar
aquanaut20
What make and model brake controller are you using??
you should have 4 wires,
  • Battery power
  • Main ground
  • Switched power
  • power to trailer brakes
Old Aug 14, 2009 | 10:45 PM
Aggie05's Avatar
Aggie05
Thats correct, i have 4 wires blue = trailer brakes, white = ground, black = battery +, red = brake line.
Its a hopkins agility.
ill paste link below.
http://www.hopkinstowingsolutions.co...e_control.html
Would love some input, need this working by this weekend.
Old Aug 14, 2009 | 11:37 PM
Aggie05's Avatar
Aggie05
bump for help.
Old Aug 15, 2009 | 12:10 AM
aquanaut20's Avatar
aquanaut20
Ok, so where are you having problems?
    Old Aug 15, 2009 | 12:25 AM
    flamebuster's Avatar
    flamebuster
    sounds like you have a wire going to ground between the controller and the plug in, unless you are hooked up to the trailer then it could be in the trailer.. fuse should only blow when it is overloaded or shorted out.
    Old Aug 15, 2009 | 09:45 AM
    Aggie05's Avatar
    Aggie05
    I have not hooked up trailer wires yet, and when i disconnected the red wire the fuse doesnt pop.
    SO i need further help on finding out where to hook up the red wire.
    Old Aug 15, 2009 | 02:47 PM
    Aggie05's Avatar
    Aggie05
    Still looking for some advice.
    Thanks,
    aggie05
    Old Aug 15, 2009 | 03:10 PM
    aquanaut20's Avatar
    aquanaut20
    Thanks,
    aggie05
    If you disconnect the Blue wire (at the controller) going to the brake connection for the trailer, and connect the red to the switched side of the truck brake, does the fuse still blow??
    If you PM your Phone number I will be glad to talk you through the diagnostics
    Old Aug 16, 2009 | 03:36 PM
    aquanaut20's Avatar
    aquanaut20
    Do you have the trailer up and running/stopping yet?
    Re: the current draw for the trailer monitoring (light), the circuit employs a transistorized c/b drawing <10ma, would require >5000hrs (connected to trailer, engine not running)to draw down the average battery in the tow vehicle.
    Old Aug 17, 2009 | 11:38 AM
    Aggie05's Avatar
    Aggie05
    Special thanks to aquanaut20 for calling me on the phone and helping me sort out the trailer brake problems.
    The problem was the ground on the trailer brakes was wired with the power line for the trailer brakes. There were 2 wires on the magnets and one was suppose to be a ground and the other was for power. i had both wires going for power. SO i had to ground the brakes, ground the trailer, and ground my truck.
    Thanks for help, now everything works properly.
    Old Aug 17, 2009 | 03:23 PM
    aquanaut20's Avatar
    aquanaut20
    Happy to help, glad you worked out the problem.
    Just click on my reputation button.
    maddmatt02
    Dec 4, 2017 08:00 AM
    Peter Gill
    Jun 21, 2016 02:22 AM
    metriccar
    Apr 25, 2012 11:05 PM
    79fordf250pickup
    All Things Towing
    21
    Mar 9, 2011 09:30 PM
    apbtpetey
    Electrical Systems/Wiring
    13
    Oct 25, 2010 10:22 PM
