Can only get fourth gear
Old Jan 24, 2005 | 12:35 PM
kray's Avatar
kray
I have a 95 F-150 and can only get fourth gear. I have put in a new slave cylinder and checked the clutch and pressure plate they look fine any ideas on what else to check on before I check the transmission?
Old Jan 25, 2005 | 09:13 AM
low-side's Avatar
low-side
You might check the bushing where the shifter enters the trans., but if you can only get 4th you're probably looking at bent shift forks.
Gotanoldtruck
39
Nov 7, 2016 03:52 PM
traviseruss
Jan 20, 2015 07:25 PM
cabby02nyy
20
Nov 11, 2012 09:00 AM
roller_steve
Oct 21, 2011 07:50 PM
Titan077
18
Feb 26, 2005 10:46 PM
