255 motor???
Old Jan 23, 2005 | 09:02 PM
novadragman2005's Avatar
novadragman2005
Exclamation 255 motor???
I think i may have a ford 255 motor, does this motor even exist or am i making things up?? i though i saw before on a website that they do exist but i cant remeber. anyone know how much they are worth or when they were made?
Old Jan 23, 2005 | 09:50 PM
Racerguy's Avatar
Racerguy
The 255 was built in 1980, 81 and 82.
It's a real thing of beauty....or not.
It looks like a 302. It has heads with very small oval shaped intake ports, tiny valves etc.
They had around 120 hp.
I've thrown a couple of them out. I doubt you'd find someone that would give you anything for it other than for the scrap metal.
Old Jan 23, 2005 | 10:22 PM
novadragman2005
i got a guy who wants to buy it for like 50 bucks to put in a jeep, are there any performance parts available for it?
Old Jan 23, 2005 | 11:49 PM
Racerguy's Avatar
Racerguy
A small block cam will fit and headers should be the same. I don't think anyone makes a good intake for it. A 302 intake won't fit because of the ports.
Old Jan 24, 2005 | 01:15 AM
grampztoyz351's Avatar
grampztoyz351
They make good boat anchors
Old Jan 24, 2005 | 01:19 AM
Racerguy's Avatar
Racerguy
The nice way to say it is that they are good for marine use
Old Jan 24, 2005 | 03:43 PM
tbirdscott's Avatar
tbirdscott
Unfortunately I have a 255 in my tbird it was designed to be better on fuel(by 1mpg), lighter(by 60lbs), and more powerful(by 10%), than the 5.0 aswell as share 85% "commonallity" between the engines. It has a smaller bore therefore smaller valves and runners to accomodate it. The engine was lightened by using an open-webbed aluminum intake, a hollow crankshaft, and the engine block was lightened by reducing wall thickness and bolt-boss diameters. "The 4.2-liter is the newest addition to the ford family of high-output engines" with a whopping 119 hp! and (I believe) 130 ft/lbs of torque
It shares the same cam and exhaust manifolds aswell as *maybe heads but since the intake is narrowed by 15% over the 302 there are no aftermarket pieces available.
If someone will give you $50 for it offer to deliver it for free and run laughing! its not very fuel efficient (especially after 25 years) it isnt powerful (although it does zip around 3-4000 rpm nicely) and they would be just as or more expensive to rebuild than a 302 or 351w
Old Jan 24, 2005 | 06:55 PM
novadragman2005
r there any parts available to rebuild it? the guy wants to put it into a jeep so what would be needed for the conversion, it also needs completely rebuilt, will he find stock parts?
Old Jan 24, 2005 | 09:54 PM
tbirdscott's Avatar
tbirdscott
I actually just checked and a rebuild kit (bearings, gaskets, rings) is only $20 more than one for a 302 and you should be able to get oversized pistons if needed, The only things that would appear to be 255 specific are the block, intake, and heads which could be re-used. Personally I would still go looking for a 302, i've sold rebuildable long blocks for $25 (and thats canadian!)
Old Jan 25, 2005 | 01:11 AM
grampztoyz351
Sorry Racerguy I've never been one to politically correct!!! My bad ,Jeff
Old Feb 2, 2005 | 09:55 PM
RacinNdrummin's Avatar
RacinNdrummin
Nothing will interchange between the 2 motors. All they did to create the 255 was to shrink the bore of a 302 to 3.5", put on smaller heads with ghetto "tunnel-port" style runners, smaller valves, 1.68" intakes I believe. You cant put 302 heads on it because the bore is too small, and you cant bore it past 3.540". No aftermarket intake for it, and a 302 intake will not work because of the ports. the stock heads could be worked over a bit and the cam does interchange but the intake still sucks. Im pretty sure the 255 had about 200lb.ft not 130. Sell it to the guy and buy a 302.
Old Feb 3, 2005 | 04:10 PM
tbirdscott's Avatar
tbirdscott
RacinNdrummin you are right about the torque. I found some more reliable specs on the 255
For 1980-1981
115hp @ 3800rpm
194lb @ 1400rpm
8.8:1 cr
For 1982
120hp @ 3400rpm
205lb @ 1600rpm
8.2:1 cr
sand man
May 9, 2023 12:38 PM
Marty N Debbie Sapp
1997 - 2003 F150
Jul 8, 2014 12:19 AM
davidalan1731
Dec 23, 2010 06:05 PM
Nate_Gutierrez
Nov 15, 2010 11:26 PM
petepetersen
Apr 29, 2010 08:18 AM
