6.0 intermittent miss HELP!
Old 12-22-2010, 04:47 PM
davidalan1731's Avatar
davidalan1731
davidalan1731 is offline
<hr style="color: rgb(255, 255, 255); background-color: rgb(255, 255, 255);" size="1"> 6.0 after changing injectors and doing a sinister EGR delete the truck runs great. BUT EVERY so often it will miss. I cant pull any codes on my edge evo but it doesn't do it all the time. Any Ideas TIA
Old 12-22-2010, 06:18 PM
cheezit's Avatar
cheezit
cheezit is offline
miss at idle or going down the road?
best bet is to have a scanner that can watch balance to catch the concern
Old 12-22-2010, 06:22 PM
High Binder's Avatar
High Binder
High Binder is offline
What year?
Old 12-22-2010, 06:38 PM
davidalan1731
Miss at idle and on the road. It's barely noticeable at idle but really bad when I get on it. I just got a code for cyl 4, P0272. Got the same code right after all injectors changed about 300 miles ago. Back then, I pulled the FICM and found a bent pin. Straightened it and she's been smooth every since. This morning (in stock) I felt the miss but no codes and it smoothed out after about 15 miles. This time the code showed up. All temps look good. Forgot to mention that also did a new oil cooler with the EGR delete.
I'm thinking CPS or FICM going bad but Im guessing.
Thanks
Old 12-22-2010, 06:39 PM
davidalan1731
Sorry, it's a 2005 F250 4WD
Old 12-22-2010, 06:40 PM
davidalan1731
Also had a VSS error. I think the code was p0500. But the speedometer is working fine.
cheezit's Avatar
cheezit
cheezit is offline
ficm is easy enugh to test.
we dont see cmp or ckp sensors issue often. in fact Ive done more harness then sensors.
I would really suspect an injector. if they came from ford there is a 12/12 warranty on them
Old 12-22-2010, 06:50 PM
davidalan1731
I'll check the FICM tomorrow a.m. I was hoping the CPS may have been bad (reading another thread somewhere on here). Do injectors go bad that quickly? What would cause it only 300 miles since the change? Thanks
Old 12-22-2010, 06:56 PM
cheezit's Avatar
cheezit
cheezit is offline
see it happen befor. just because a part is new does not make it a good part.
check fuel pressure.
Old 12-23-2010, 01:56 PM
davidalan1731
Cheezit,
Took it to dealer this morning for testing. You were spot on about the fuel pressure. 50 at idle, 38 max under boost. Dealer installing new pump and regulator now. Thanks.
Correction: Bought new pump and regulator...I'll be installing them this afternoon. They wanted $400 to install them. OUCH!
Old 12-23-2010, 02:01 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
The old cheeze's brilliant saying of the month.
Old 12-23-2010, 04:31 PM
davidalan1731
Thanks Cheez...pump and regulator for sure. Now it's screaming again. Is there an aftermarket fuel pressure gauge I can add to monitor? My Edge wont do it.
Old 12-23-2010, 05:57 PM
cheezit's Avatar
cheezit
cheezit is offline
lots of gauges available. glowshift, motorcraft, auto meter, etc all make them. it will require a little bit of work and a fitting or 2 to make it happen.
Old 12-23-2010, 06:05 PM
davidalan1731
Sounds good. Thanks for all the info
ruffneck30
11-08-2014 06:38 PM
Troy_C
1999 to 2016 Super Duty
33
11-15-2013 06:55 AM
DallasSuperCrew
2004 - 2008 F150
04-02-2013 09:28 AM
Dual Liner
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
12-20-2010 08:03 AM
74f250scs2wd
02-02-2010 07:37 PM
Quick Reply: 6.0 intermittent miss HELP!
