Sponsored by: Auxito
check engine light...
Old Jan 23, 2005 | 05:36 PM
andyfritsch's Avatar
andyfritsch
My light just came on this A.M In my '97F150 5.4L. as I tried to go for a ride in our New England Blizzard. It's idling poorly and running very rich. Can anyone point me in the right direction. Thanks. AF
Old Jan 23, 2005 | 08:27 PM
bosshoss's Avatar
bosshoss
Hello.
Burrrrrr. I would see if a parts store can check the codes for you. There are a few that wont charge for this, like AutoZone, or AdvanceAuto Parts. Let us know what the code number is, this would be a good start point. Welcome to FTE.
Time for something hot. ummmm.
Dave P.
Old Jan 23, 2005 | 09:35 PM
cantrma's Avatar
cantrma
If it's running rich after being warmed up it could be the ECT went south, cheapest and easiest by far and fairly likely. Fuel pressure regulator could be stuck. Or if it's only rich at idle, the vacuum line to the fuel pressure regulator could have come off. If it ONLY does it when cold and QUITs when it's warmed up, the MAF could be bad or disconnected. Wiggle the connectors to everything before condemning them. A little moisture can screw up a connector when it freezes and expands.
Let us know when it happened. Before then engine warmed up, after the engine warmed up, or both. Only at idle, only at off idle or both? When did the light first come on?
Old Jan 24, 2005 | 07:54 AM
MBDiagMan's Avatar
MBDiagMan
Get the code first. Don't start fishing until you know where the fish are.
Good luck,
Doc
Old Jan 25, 2005 | 04:30 AM
andyfritsch
Yeah, I was able to get someone to look at it yesterday. The code was a misfire on #8 which caused the rough and rich condition. Seems this nast blizzard drove snow right up in to the engine compartment resulting in water down to the coil and plug. Hmmm. Any thoughts on preventing this short of moving south. Those coils an plugs aren't cheap. Thanks. AF
Old Jan 25, 2005 | 11:24 AM
MrBSS's Avatar
MrBSS
The COPS have been a weak point. I would advise you get the latest Motorcraft coils from Ford, and use dielectric grease around all terminal seals.
Oh wait, ...a '97 wouldn't have COPs. But do use the dielectric grease.
Frankiec#1
Feb 15, 2021 09:47 AM
brent1204
1983 - 2012 Ranger & B-Series
Mar 26, 2014 10:57 AM
abyars111
Nov 12, 2012 09:18 AM
tjdad62
Aug 19, 2011 05:42 PM
JNKDad
Dec 22, 2007 06:22 PM
