Sponsored by: Auxito
Coil Problems
Old Jan 25, 2005 | 02:07 PM
bumpwhite's Avatar
bumpwhite
Coil Problems
I posted this else where before realizing I posted on the wrong forum.
During Christmas, I lost two coils simultaneously in my 2002 F-150. It appears to have occurred when I went to two wheel drive from four wheel drive. I thought it may have been coincidental so when I got my truck out of the shop, I put it into four wheel drive then back into two wheel and the truck started to miss and about 30 minutes later the check engine light came on. Taking it back to the shop, one coil was bad on the same cylinder as was previously replaced. The repair work was not done at a Ford dealership.
Is it possible switching from four wheel drive back to two wheel drive could cause a high voltage current to the coil? I can't believe two coils would go at the same time unless it is related to some other problem. By the way, I have kept the truck in two wheel drive since replacing the last coil and it is running fine.
Thanks!
Old Jan 25, 2005 | 02:34 PM
cantrma's Avatar
cantrma
According to Ford, well over 1/2 of all coils returned by dealer mechanics (under warranty) are not bad. Your coils very well may not have been bad either. If they were, it wasn't related electrically to the shift. Is it a vacuum shift?
Old Jan 25, 2005 | 03:36 PM
bumpwhite's Avatar
bumpwhite
I think the shift is just electronic. I read where 1/2 of the coils replaced were good but when the coil was replaced, the problem went away making me think the diagnosis was correct.
