Higher amp, or 1 wire alternator
Old Aug 2, 2002 | 08:24 PM
bigin302's Avatar
bigin302
I'm looking for a higher amp alternator for an 84 F-150. I want to put a winch and some lights on it and I already have an electric fan, but the one on it now only puts out 61 amps. I'd like to have one with atleast 100 amps. Any suggestions? How do one-wire alternators work? Anyone know?
Old Aug 3, 2002 | 07:14 PM
Paso1's Avatar
Paso1
[updated:LAST EDITED ON 03-Aug-02 AT 08:15 PM (EST)]I have a one wire alternator on my Corvette. The only problem with the 100 amp one wire alternators is that they don't put out at idle. This is usually not a problem but If you check output at Idle it's usually barely enough to keep the batt light out. Hook up is exactly as it's name "one wire"
Old Aug 4, 2002 | 09:07 AM
davewild's Avatar
davewild
I am not sure what motor you have but I put a Ford 3G 130 amp alternator on my 79' 351M, I am sure you could find one of these alternators to fit your motor. The 3G alternator is an internal regulator, just as easy to hook up as a one wire alt.
Good Luck,
Dave Wild
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3982&.jpg
Old Aug 4, 2002 | 04:13 PM
brokebronco's Avatar
brokebronco
kincfu
Mar 9, 2016 11:20 AM
jlw247
Apr 3, 2015 11:42 AM
JonArmy
Feb 2, 2013 07:54 PM
octaneforce
Jul 20, 2012 06:33 PM
superbepro
Sep 12, 2005 06:10 AM
