Left & Right Upper Control Arms are Different???
Old Jan 23, 2005 | 08:57 AM
Almost_A_Merc's Avatar
Almost_A_Merc
I have a 1996 AWD 5.0 Explorer and I recently took it in for a front ent alignment... (Infact it's still at the shop). As they started to align it they pointed out to me that the Right Upper Control Arm is different then the Left. The Right one has what appears to be another method to adjust camber(?) bolted on about halfway point and the left is one solid piece with two Cam style adjusters at the mounting points. The shop is saying something has been changed, and they believe the right one is correct... any input would be greatly apprecieated!
Thanks & God Bless,
David
Old Jan 23, 2005 | 01:00 PM
ukexplorer's Avatar
ukexplorer
My 99 4.0 SOHC Explorer also has different LH and RH upper control arms. According to the Haynes manual this is correct. The RH adjusment is to get coarse adjustment right between left and right before final adjustment with the cam adjusters at the mounting points.
Good luck
Old Jan 23, 2005 | 01:31 PM
marragtop's Avatar
marragtop
I just had new upper/lower ball joints and control arms replaced on my '95' The control arms are definitely different. I'd consider finding another front end shop.
Mike
Old Jan 24, 2005 | 04:33 AM
95EXPLODER's Avatar
95EXPLODER
Mike
What he said especially the part about finding a diffrent shop.
Old Jan 24, 2005 | 06:17 AM
rblais's Avatar
rblais
I recently replaced the two upper and two lower ball joints on my 2000 Mountaineer, V8. Of course to replace the upper ball joints you need to replace the upper control arms. My truck had the two different types of control arms like yours; single piece on the left and two piece on the right. The replacement control arms, however, are the same for both sides-single piece like the original one on the left. It took some convincing by the parts guy and the Ford mechanic that this was correct before I purchased them, but I did. The control arms have been in the truck for about 4K miles with no problems. If you ordered left and right upper control arms from Ford I think you would receive two SINGLE piece control arms, almost identical except for slightly different geomtry between the left and right arms. Your shop is correct, the control arms are the same.
Old Apr 26, 2008 | 05:35 PM
eallanboggs's Avatar
eallanboggs
If you look at them closely they are slightly different(upper drivers side compared to upper passenger side). The new upper control arm for the pass side replaces the two piece system. The single piece on the pass side is different from the drivers side control arm and has a different part number. I don't know if they are interchangeable, but they are very similar.
Old Apr 26, 2008 | 08:59 PM
Soulseeka's Avatar
Soulseeka
Just replaced all four on mine today. Only took about about 3 hours. That right side upper is different and it's super easy to change.
Old Apr 27, 2008 | 11:32 AM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
The left side upper control arm is a single piece. The right side upper control arm is a dual-piece.. the inner half.. and the outer half (which bolts onto the inner half).
They did this so they could quickly adjust the caster on the right side at the factory, to match what the left side is at.
Ford has since changed the design of the replacement part to a one-piece control arm on the right side, although some aftermarket companies still produce the two pieces.
Old Apr 27, 2008 | 07:36 PM
Soulseeka's Avatar
Soulseeka
So what Advance was showing me was ok to use? I just thought they didn't have the correct parts. Could have saved a few bucks, but it woulda taken loner to do.
Does the OE design make it easier on the guy doing the alignment?
FordTruckChuck
1997 - 2003 F150
67
Nov 13, 2015 04:37 PM
87&97Aerostrar
Aerostar
Aug 20, 2015 10:50 AM
Easywin
Jun 15, 2011 12:36 PM
WillFargo
Dec 9, 2010 10:22 PM
aerocolorado
Aug 25, 2004 04:52 PM
